warped rotors..
Excess run-out causes wobble or pounding. In the middle of the pad
wear area, if it exceeds .004 inches, replace or refinish the disc.
To check Disc parallelism, measure disc thickness with a micrometer in 8 different equally spaced places.........about 45 degrees apart. If measurements vary by more than .0006 inches, replace them
............not that much more costly than machining them down.-Bob
ohh ok wow .0006" that is pretty tight but I guess you really do want them flat...
look man if you do not know where or where to measure then you will def have a margin of error greater thean what you are looking for. take them to napa ask to have them resurfaced. if they are to thin they will tell you.
it is a good idea when doing a brake job as it will help eliminate any squeeks etc..
the bigger the vechicle the larger the tolerance for run-out,a huge truck will not be affected by .006" run-out ,but on a civic or something of similar size a .005" should be machined. and Bob, i'm prettey sure you made a mistake ...its more like .006" and you can still machine it if its in spec.
and you want to measure them in the deepest groves doesnt matter exactly where ,as long as the measurements are spread out.
and please for the love of god, dont go to any so called "brake Speacialist " places .they will just fuck you for your money.
Guest
Posts: n/a
true that, my friend with a 02 WRX went there to get his pads replaced, the car had 65k miles. They told him that he needed a caliper rebuild and thats why his fluid was low because they were leaking. I told him they were full of shit and to put new pads on it, and, surprise! look at that, the fluid level came right back up!
Awright, fourbanger! I copied my numbers right from the book, and just checked another book, ...........and both read the same................
Sooooo.......I called all the autoparts places near you, and told them what you said about the manuals they sell.........
To a man, they all said they would kick your
A--, next time you walk in!
-Bob
-Bob
rotor discussion
