Horsepower and Torque..What??!
Old Sep 29, 2005 | 08:00 AM
  #31 (permalink)
toast's Avatar
Originally Posted by HybridSS
your missing some info and have a few things crossed up. Saying that a car with 100 hp and 100 ft lbs makes max power at 5252 isnt right. How in the world can you make that inference? Now if you say the car makes 100 hp AND 100 ft lbs at the exact same time and both are peaks..then yes...it will be at 5252 rpm. Not many cars will make both peak HP AND peak Tq at the cross point of 5252. As a matter of fact I have never seen one. Usually peak Tq is made substantially lower in rpm than peak HP. In other words...just saying the cars HP peaks at 100 and the Tq peaks at 100 is pretty useless to make any prediction on how the car may accelerate. You really need to know what the entire Tq curve (and HP curve) through the RPMs looks like.
Even if we look at yout theoretical engine where we say it makes those peak #s at THE SAME TIME...you still cannot tell which one would be faster. Maybe the one that makes 100ft/lbs at 5252 rpm also makes 95 ft/lbs all the way out to 7500 rpm....and then is geared accordingly. And the other engine drops off drastically just after 2700 rpms. Looking at peak #s alone will never tell you anything. Do yourself a favor and go read the link posted.
No, the engines HAVE to exist that way, its not theorhetical. Its:
RPM=(HP*5252)/RPM.
You say "what if it also makes 95ft-lbs all the way to 7500? Then:
HP=(TQ*RPM)/5252
Hp=(95*7500)/5252; HP=~136
You see? Then its PEAK HP is no longer 100! It no longer fits the example. It changed, all Im doing is using the exact variables you gave me to do some calculations. The big problem here is you guys are trying to boil it down to HP vs TQ. This really cant be done, the formula to FIND HP, includes RPM.
Ghost, my good buddy. Put that Cam on there and prove my point. Run a dyno before AND after, not only will you gain tq.. you will also gain power. Its so obvious it figuratively kicking you in the face:
HP=(TQ*RPM)/5252
Ok your drag engine that you build gets 100hp/100ft-lbs tq at 5252 rpm.
Now we put in your cam and gain 10ft-lbs tq.
HP=(TQ*RPM)/5252
HP=(110*5252)/5252; HP=110 OMG you gained power to! That must be how you moved down the track faster!
Torque is a FORCE, applying a force to something means nothing. Go outside and push on your house. Your applying a FORCE to it but doing NO work. As soon as that FORCE moves something then it is doing WORK (which horsepower measures).
You also CANNOT leave RPM out of the equation, trying to boil it down to HP vs TQ sounds nice but you can't do that and expect truely understand whats happening, all three variables are dependant on eachother.
Btw, I have read that article before and IMO reading an arguement between a few members isnt the best way to learn. Obviously one of them has got to be wrong and when their arguements are as long and somewhat convoluted as theirs were it gets very confusing.
Old Sep 29, 2005 | 09:11 AM
  #32 (permalink)
HybridSS's Avatar
I have fuzzy eyebrows
RPM=(HP*5252)/RPM.
HP=(TQ*RPM)/5252
Good catch. I should not have made the example have more HP. But what I said about looking at the peaks alone still holds true. I should have given an example of the Tq dropping off drastically instead of maintaining it through the rpm. But as far as you making the inference that the two cars...one making 100hp and 100 tq (at5252)and one making 100hp and 200 (at 2626) will tie is still wrong.
Lets look at what might be possible given tha parameters you have laid out.
engine 1: peaks at 100 both HP and Tq at 5252
but what about the rest of the rpm range?
2000 rpm = 25 ft/lbs 25x2000/5252= 9.5 HP
3000 rpm = 30 ft/lbs 30x3000/5252= 17.1 HP
4000 rpm = 60 ft/lbs 60x4000/5252= 45.7 HP
5252 rpm = 100 ft/lbs 100x5252/5252= 100 HP
6500 rpm = 50 ft/lbs 50x6500/5252= 61.9 HP
Now thats a peaky POS motor but it still is within the parameters you stated.
Now lets compare the other engine and keep it within the paremeters you stated of 100 hp and 200 tq at 2626 rpm
2000 rpm = 199 ft/lbs 199x2000/5252 = 75 hp
2626 rpm = 200 ft/lbs 200x2626/5252 = 100 HP
3500 rpm = 150 ft/lbs 150x3500/5252 = 99.96 HP
4500 rpm = 115 ft/lbs 115x4500/5252 = 98.53 HP
5500 rpm = 95 ft/lbs 95x5500/5252 = 99.48 hp
6500 rpm = 75 ft/lbs 75x6500/5252 = 92.8 hp
Its glaringly apparent that engine #2 will STOMP a mudhole in engine #1 one if they were in the same car with the same gearing and same weight. And we have stayed withing the constraints you set. Obvioulsy these are extreme examples. Like I said...looking at peaks alone really doesnt tell you much.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Sep 29, 2005 | 01:48 PM
  #34 (permalink)
toast's Avatar
Alright, I see that we both have the right idea here, what you say is true. I was just going off of someone's question using the 2 cars assuming everything else was held equal.
Old Sep 29, 2005 | 01:52 PM
  #35 (permalink)
Fritchard's Avatar
I got fired last week
so I guess diesel engines can factor into this too eh?
lots o torque, but no rpm
Old Sep 29, 2005 | 02:29 PM
  #36 (permalink)
Suicidal Racing's Avatar
Has V.I.P in HELL!
sorry but the car will run faster due to there being more tq witch= faster 60ft times there for u will run faster in the 1/4.it has nothing to do with hp and i know this for a fact becuase i get custom ground cams done all the time.oh an yes the engine made power at the same rpm level and had the same hp level but 30ft lbs of tq.just think if i had a big block that made 700hp and then a small block that made 700hp the big block will run faster in the 1/4 due to more tq.
Old Sep 29, 2005 | 02:45 PM
  #37 (permalink)
HybridSS's Avatar
yeah...I can see from your last post you obviously understand. I am with you on the "Tq without rpm means nothing". Thats definately true. This whole subject is hard to debate and think about while throwing around different parameters.
Old Sep 29, 2005 | 07:50 PM
  #38 (permalink)
toast's Avatar
"oh an yes the engine made power at the same rpm level and had the same hp level but 30ft lbs of tq."
This statement is all that is needed to prove you wrong. Sorry man. But just look at the equation.
HP=(TQ*RPM)/5252
There is absolutely NO POSSIBLE WAY that you can change TQ without changing the HP number at the end of the equation. You might as well try to tell me that 1+3=1.
Old Sep 29, 2005 | 08:38 PM
  #39 (permalink)
Has V.I.P in HELL!
if i still had the damn dyno sheets i would show u them.
