process to making paint stick
Old Mar 3, 2005 | 05:28 AM
94lsteg's Avatar
BOOST IS BETTER!
Default process to making paint stick
....on rotors.. Will the regular "engine Enamel 500 deg" stuff work, or what do i need to do to get the paint to stay for a long time...thx
Old Mar 3, 2005 | 05:30 AM
PantySniffer's Avatar
grippin grain
Are you paintin calipers, or rotors? I've never heard of anybody painting rotors before ?
Obsession is a word used by the lazy to describe the dedicated.
GO GATORS
Old Mar 3, 2005 | 05:34 AM
94lsteg's Avatar
BOOST IS BETTER!
well, im doing the calipers too, and i got the "caliper paint" for them. YES, the rotors inner circle part. It gets all rusty if you dont paint it......BTW: im painting them JDM HOT PINK....
not really, black is my choice of color..
Old Mar 3, 2005 | 05:49 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
dont paint them, just use heatwrap... That seems to be the new hawtness these days....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Mar 3, 2005 | 05:57 AM
myltwon's Avatar
Bolt-On 2v GT
+2131241513567 heatwrap on my rotors saved me from crashing multiple times
Old Mar 3, 2005 | 07:24 AM
Clifford's Avatar
weezin the juice
wtf is everyone bringing up heatwrap for on TR now???? I dont get it i.e. my cat died-heat wrap it wtf?
Old Mar 3, 2005 | 07:25 AM
94lsteg's Avatar
BOOST IS BETTER!
I WOULD! but I think Matt already did it dammit!....F'n heatwrap king he is....
Old Mar 3, 2005 | 07:43 AM
94lsteg's Avatar
BOOST IS BETTER!
yea, back on topic, TTT
Old Mar 3, 2005 | 07:48 AM
myltwon's Avatar
Bolt-On 2v GT
Rotor Painting
Tools Needed
Tape Measure
Poster-board
Rubbing Alcohol
Compass
Double Stick
Tape Hobby Knife
Painting your rotor hats not only keeps them looking good, but also protects them from rust. Any high temperature rated paint will work for this job. When choosing a paint look for one with a sustained heat rating of at least 600º. For a high-gloss colored finish, caliper paint will work well. For those of you looking for something more subdued and stock in appearance, BBQ grill paint will also work well. As with all painting, preparation is critical. Before you start to paint, remove any rust there may be and swab the entire surface to be painted with rubbing alcohol.
Using a tape measure, determine the diameter of the hat. Assuming a 7" diameter, set your compass for a 3.5" radius. Now draw and cut out a 7" hole in the center of your poster-board. You now have a template to protect the braking surface during painting. Using the piece that was cut out, make a shield for the area of the rotor that the rim comes into contact with. With that done, secure the paint shield to the rotor with double stick tape. Shown above are the two templates. Paint the two front rotors first, as they are smaller. When using spray paint multiple thin coats should be applied to avoid drips and runs. Once finished, you will be left with a set of very professional looking rotors that should look good for years.
The above rotor was painted with a semi-gloss black BBQ grill paint. Three coats were needed to achieve a smooth uniform appearance.
