Harnesses-which&why?
Originally posted by Chuck 98 RT/10
HANS will cost you more than $1,000. You wear it and it is attached to the helmet to keep your neck from snapping off. A common and fatal injury. IMO it's overkill (no pun intended) for amateurs since most rarely reach the speeds as the pros or are involved in pro-like race conditions.
Now, if you're running 6-second quarters or hitting 180 on the back stretch at Sebring...
I have Simpson five points.
Originally posted by Whaazup17
your crazy man
your crazy man
But I don't subscribe to the "no expense too great for safety" attitude. Eventually the "safety extremist" will require all drivers to be wrapped in a vel-cro cocoon and the only thing you'll be able to move is your pinky finger.
Helmet - good for all cars.
Seat belts - good for all cars, safety harness even better.
Roll bar or cage - depending on ET or type of racing - good.
Hans - Good for F1, CART, Indy, NASCAR, John Force, but unnecessary for a street car.
Jeeze Whaz, your bashing me for my Hans comment? Some of these folks actually think a 5-point isn't as good as a standard seat belt.
BTW Whaz, do you have a Hans?
Originally posted by Clifford
...-"also think about getting a hans device or isaac device"....???which is?
www.simpsonraceproducts.com
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
Chuck
I have g-force 5 point 3" and a bolt in roll bar - I have the latch kind...
Now five point - vs 6 point - with five point typically you'll have to drill a hole in the floor. Six point you can usually attach each leg side to the seat rails.
No Hans Device - and i'm only up to 140 before turn 17
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower"
-Mark Donohue
-Mark Donohue
http://www.ogracing.com/
http://www.stableenergies.com/home.asp
http://www.theracedepot.com/product10-9.htm
-Mark Donohue
-Mark Donohue
Originally posted by 60-1EK
The problem with running a 5 pt harness in a car that has no cage is that if you were to flip your car, you are stuck. With a normal seat belt, you can lean, bend down, etc.
I'd take a 5-point over a 3-point any day.
Chuck
Chuck
Chuck
Chuck
I was looking at the gforce belts...3" 5point, camlock...Also instead of getting a cage I have thought of just welding in a couple bars., one that would be up around the roof and then one going from behind the seats...Also what owuld the difference be if i did have a cage...i still wouldnt be able to move, thats what the harness is made to do, keep you in your place.?
i think the harnesses would be for competition use, more so than every day. and probably just to stay in the seat a little better.
and, if you manage to flip an s13 youre doing something really wrong, and probably deserve spinal cord injuries.
You don't see any race cars with airbags do you? That's because a harness makes airbags totally useless.
A Viper bud of mine was wearing his harness at a track when he went head first into a wall. The airbag deployed and he said the 5-point harness kept him from ever even touching it. That would not be the case with standard 3-points. He said he remembers it all in slow motion and actually saw the airbag deploy.
Chuck
Chuck
