K&N oil filters
Old Aug 16, 2004 | 05:47 PM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
Originally posted by jdk
I don't, I order them from amsoils website. They proccess your order fast, and I order them before I need them so I have 'em ready (IE, if you're changing your oil this weekend, order one now :lol )
http://www.amsoil.com
The filters you want are 'SDF'
From this quote it seems the K&N is better than the amsoil:
"...other excellent candidates would be Hastings, K&N, and Purolator PremiumPlus. All three of these filters flow just as well or better than the Mercruiser, have better filtration, and give the added benefit of more media / increased sump capacity. The Amsoil would have to be another viable candidate since it filters much better than the Mercruiser and it flows almost as well."
Old Aug 16, 2004 | 06:10 PM
jdk's Avatar
jdk
Non ducor, duco
The K&N flows a bit better, but has less filtration ability.
Old Aug 16, 2004 | 07:14 PM
Alan's Avatar
drives euro trash
Originally posted by Illswyn
I hand tighten and loosen my filters. Unless you get oil on the filter, it's not that hard to remove. Or use a screwdriver.
The screwdriver is the most fun, of course.
I also hand tighten my oil filters, but sometimes they just get stuck on there. The oil filter on my Scion is a bitch to get to with an oil filter wrench or with the ghetto screwdriver stabbing technique (had to use to remove the factory filter). The K&N works perfectly should I need something other than my hand to take off the filter.
Old Aug 16, 2004 | 08:48 PM
I think I might start using the K&N. All they have at discount by me is Pureone, K&N, and Fram. I refuse to use fram so Pureone is the only other choice if I don't go with K&N. I like the Mazda OEM ones but then I have to go to the dealer everytime I change my oil, which is pretty often. I have heard that its best to change your filter every other oil change, is this true? Even with the $10 oil filter it makes oil changes come out to about $20 which is good considering I'm using premium products.
Old Aug 16, 2004 | 09:03 PM
Road Rage's Avatar
Shake n' Bake
I use a k+n filter on my bike, seems to be doing pretty good and is easier to get off with the nut on the end....
Old Aug 16, 2004 | 09:04 PM
  #17 (permalink)
Road Rage's Avatar
Shake n' Bake
Originally posted by mikeyees13
$10 ?!?
That's too rich for my blood!
Thats not alot when you put thousands into a motor and want it to last.....
Old Aug 16, 2004 | 09:24 PM
  #18 (permalink)
Exactly what I'm thinking. I just spent thousands on my engine and it has 250 miles on it total.
