how do i stop boost spike?
Old Jul 8, 2004 | 07:32 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
Angry how do i stop boost spike?
my boost is set at 14psi but it will only boost to like 12psi sometimes but if it only goes to 12psi i can let off and then get on it again and it will go to 14psi, i was told this is boost spike, how could i prevent this?
Old Jul 8, 2004 | 07:41 PM
_Charles_'s Avatar
formerly 'RiceRocket'
Default Re: how do i stop boost spike?
new wastegate?
Charles
My Blog: www.HotRodCaddy.com
Old Jul 8, 2004 | 07:44 PM
TIM TIM TIM's Avatar
could be worse
waste gate prolly.... and i think a bost spike is when you hit liek 18 then drop to 14...the spike would be 18... i think! dont hold me to that
aim:because tim said
Old Jul 8, 2004 | 07:47 PM
ya sometimes ill hit 15psi and it will drop to 12psi for no reason so i think its the wastegate, is there any cheap fix for this? or do i need a whole new actuater, by the way its on a tdo5 14b turbo
Old Jul 8, 2004 | 08:07 PM
could be worse
im not that sure to be honest... im not a huge turbo junkie, im sure keith or sombody with better info will chime in....
Old Jul 8, 2004 | 08:46 PM
dan's Avatar
dan
Get the fuck off my lawn
i'd get a new (or if available an upgraded) actuator assembly. it could be that yours is old and not opening fully.
if you have time pull the turbo and look at the flapper valve on the turbine housing. there could be crud or carbon buildup/soot on it keeping it from opening fast all the time. hit it with some wd-40 or penetrating lube. it might have to be replaced.
check your vacuum connections and make sure that everything is leakproof.
i dont remember but the stock boost on a 1g dsm is like 9 or 10psi..or was it 12psi? either way, an upgraded actuator might hold higher boosts more. in the nissan world, the stock sr20det actuators dont hold boost too well over 12psi sometimes, esp running 1 bar (~14psi).
Old Jul 8, 2004 | 08:48 PM
well what is the best way to look for leaks? there is soo many hoses
97TSI's Avatar
Jewbling
i would check your boost controller...when i put mine in a while ago i starting spiking 1-2 psi...Now boost creep is associated with the wastegate flapper being pushed open more then it should be..hence the creepage in pressure
check all your vac lines for cracks,holes,kinks and make sure there as short as they can possibly be
do a search on boost spike...youll see that most people replies will be somthing related to the boost controller
just my 2 cents
Good morning Hebrews and Shebrews ...wut a glorious jewish day...lots of coupons in the sunday paper eh, lots of good deals there...so i went into the store to buy a T.V. and they wanted $800 bucks for it so i "ussed" them down to $500
~Peter Griffin
Old Jul 8, 2004 | 09:08 PM
well i have a mbc but its pretty old so i was thinking of making my own so does anyone have a link on how to do so?
