how do i stop boost spike?
Old Jul 8, 2004 | 09:19 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
Originally posted by Vapor
man you own a dsm and dont know about www.vfaq.com?
i do but the link on how to do it dosent work cause that site is never updated
Old Jul 8, 2004 | 09:24 PM
google it. People have WELL documented on how to do this many times over. I'm surprised at the simple amount of words to type in on google (try MBC or manual boost controller or DIY or any combination) vs all the typing you had to do here to get the same information
wow that is soo true google pwnes me.......thanks for the help man im searching now
Old Jul 8, 2004 | 09:43 PM
97TSI's Avatar
Jewbling
even tho boost controllers are easy to make i would play it safe and just buy one..you can get a joe p for like 60 bucks
Good morning Hebrews and Shebrews ...wut a glorious jewish day...lots of coupons in the sunday paper eh, lots of good deals there...so i went into the store to buy a T.V. and they wanted $800 bucks for it so i "ussed" them down to $500
~Peter Griffin
Old Jul 9, 2004 | 10:43 AM
Rich's Avatar
Old School.
I thought we already beat this to death in the Mitsu forums, do you really think you're hurting your motor or having any serious performance degredation because of a little spike here or a little dip there?
Worry about your sustained boost levels in the gears at which you are putting the most load on the motor.
You may know who we are, but we KNOW who you are.
Old Jul 9, 2004 | 11:11 AM
  #17 (permalink)
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Yeah, once I get a MBC Joe P is the one I'm going to get, even though I wont have a DSM. I've heard alot of good things about them
Also I heard that a bad blow off valve could also cause boost spike, but dont quote me on that.
ASE: Brakes
Old Jul 9, 2004 | 12:02 PM
  #18 (permalink)
InsaneCivicCoupe's Avatar
Retired Ricer...
Get rid of that pussy ass little pea shooter turbo and put something on there that motor can actually feel.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jul 9, 2004 | 12:31 PM
  #19 (permalink)
97TSI's Avatar
Jewbling
ive never read of a BOV causing boost spike..usually a spike will originate somwhere along the boost control system...if your boost controller has a bleeder hole try making it bigger..if it has no bleeder hole try making a small one...or try a friends B/C and see if the spike still exists..its basic trial and error
Old Jul 9, 2004 | 03:58 PM
  #20 (permalink)
quickcivic's Avatar
addicted to boost
Boost spikes are caused mainly by the wastegate not being able to control the boost properly. In some cases it is the boost controller and connections. Get a quality wastegate (Tial) that is properly sized for your setup..and check for boost leaks.
You can check for boost leaks by getting a 3" or 2" (whatever turbo inlet size you have) rubber hose at homedepot, two hose clamps, and a pvc pipe cap (matching the size rubber hose) drill a 1/2" hole in the cap and get a quick connect end for an air compressor line and screw it into the hole you drilled on the cap. Connect the rubber hose with the cap all secured by hose clamps to the turbo inlet. Next, connect an air compressor to your pvc pipe cap and pressurize it at about 10-15lbs using the regulator to regulate air pressure. Listen for leaks..
-Alex
