Convince me to build an Import
240z, 260z, 280zx are also hard to pass up in the "bang for the buck" category... heck you could even go imported/domestic and swap a V8 into one of those bodies...
I dont feel like a sig today.
These guys have no imagination. How about this...
http://www.fallaclassics.co.uk/project_cosworth.htm
It's a 1978 MGB with the following specs:
2 litre RS Cosworth turbo injection
Garrett turbocharger with Escort Cosworth compressor housing and impellor
18psi wastegate actuator
ECU managed
803 Green injectors
3 bar map sensor
330 bhp ‘BSW’ chip
MGB V8 dense core radiator
Twin Kenlowe heavy duty cooling fans
MGB 13 row oil cooler mounted in front valance
Estimated 0-60 sub 5.5 seconds
Top speed capability 150 mph
Check the link and pics. Nice car. If MG had built cars like this, they would still be in business.
ECU managed
803 Green injectors
3 bar map sensor
330 bhp ‘BSW’ chip
Beer. Now there's a temporary solution. --Homer Simpson
I like these alittle better myself but I could be alittle biased.
http://www.grmotorsports.com/rospit.html
http://britishv8.org/swaps/spitrtry.htm
but I guess I would rather have a 20b in mine
If speed kills then I'm suicidal
i had a 92 grand marquis
with a saleen engine/tranny swap with 373 in the rear 400hp/400tq
it was stolen from me
now i have a 99 camry with 268 hp 275 tq
you can soup any car
i personally like 4 doors cause the bitches are sleepers and there's nothin better than kickin a 2 doors ass
but thats my opinion
99 camry v6
G-racing 18's (non-chrome)they are lightweight aluminum alloy, Bomz intake, AEM filter, RS Racing strut tower bar, NGK plug wires, Denso Iridiums, K&N oil filter (only), North Tampa Customs custom exhaust layout with no cat, 98 supra turbo fuel injectors and fuel pump, bored throttle body, 2- 5way RJS harnesses, 175 pound weight reduction, and increased throttle response
who the hell stated i had chrome rims i sure didnt
99 camry v6
Guest
Posts: n/a
you don't need to built a supra, just keep the stock 2jz-gte motor which has proven many times that the stock bottom end can handle power of up to 700+RWHP bone stock... with stock twins @ 20 psi, intake and exhaust is almost more than enough for someone who wants to experience what a supra can do.
Couple of guys (joe and chris locally that I know of) have gotten low to mid 11 second passes on stock twin turbos... but it depends on what you like - i like the idea of the 240 although nobody has given me a ride in an SR swapped 240 yet!!
