Installed the Cams on the Slocus
A few pictures of the "fun".
It all started with trying to get the wheel off. Broke some tools trying to get a lug off after Ernie Haire took it upon themselves to over tighten them.
Originally posted by phatstang1
I want to hold out until I get the header, chip, and mass air before I put it up on a dyno. So hopefully in another couple of months.
Can't wait to see how it turns out. Does it sound lopey
Marisela
Marisela
“Meditation brings wisdom; lack of mediation leaves ignorance.
Know well what leads you forward and what holds you back, and choose the path that leads to wisdom.”
~ Buddha ~
~ Buddha ~
Not much of a lope, but I suspect you may be able to hear a bit once I ditch the stock cat and open up the exhaust a bit more. The cams did change the tone of the current exhaust/intake setup...sounds "huskier" or something.
