Installed the Cams on the Slocus
Old Mar 10, 2003 | 04:59 PM
Alan's Avatar
drives euro trash
Arrow Installed the Cams on the Slocus
Well we installed the cams this weekend. I arrived at our FocalJet Mod Get-2-Gether at about 9am over in Merritt Island. Got my car in the garage at about 12, and started working on it at about 2-3pm. Finished up at about 5:30, tightened everything down, and cranked her over.
She starts, and continues to run....good sign.
I bring it upto 2500rpm for the break-in period (20mins @ 2500rpm). About 5 minutes I begin to notice something unusual. The front of my car had a nice mist of oil, as did my hood, motor, arm, etc. Its leaking oil from somewhere onto the cam gear, in turn slinging it all over the damn place. Not good.
Shut it down, cool it down and check for leaks. Check the valve/cam cover for leaks, crank it up again. Still leaking. By now it is about 7pm, and we know we have to tear into the cams again. So we take a beer break and get to it. Ends up my BRAND NEW Ford OEM camshaft oil seal is FUBAR. So I put the old one back on and everythign is kosher. So a 2-hour install turned into about 7.
So far, I am pretty happy with the gains (although minimal I am sure). Once the car hits 4000rpm the motor wants to pull all the way up to the 7000rpm fuel cutoff. Before it would just meander up to about 5500 before sputtering out of power.
My only issue now is the ECU is idling maybe 100rpm under normal, and the car shakes like a mofugger with my new polyurethane lower transmission mount. It is at the point of almost stalling under the load of the power steering and headlights. Something I'll have to deal with until I can afford a chip.
Next step....4-2-1 race header and a flip chip with a setting for street (87 octane), and another for the track (93 octane, timing/fuel adjustments, etc).
Old Mar 10, 2003 | 06:29 PM
Strokd85's Avatar
Daddy-O
didn't think roller cams required the same breakin as flat tappet? you're not really "breaking in" a roller carm.
am i incorrect in my thinking?
I am your penalty.....
Old Mar 10, 2003 | 06:51 PM
Alan's Avatar
drives euro trash
No clue. This was recommended by Crower.
Old Mar 10, 2003 | 06:53 PM
Alan's Avatar
drives euro trash
Originally posted by Mars_302
Is there an idle adjustment screw on foci?
Kinda, but there lies the problem. The ECU compensates automatically. For instance, if you want to bump the idle to 1000rpm...the ECU will go through the motions to bring the idle back down to the factory setting. The only way to fix this is with a chip.
The idle problems should clear up once I get the cams dialed in on a dyno.
Old Mar 10, 2003 | 06:58 PM
Alan's Avatar
drives euro trash
I want to hold out until I get the header, chip, and mass air before I put it up on a dyno. So hopefully in another couple of months.
Old Mar 10, 2003 | 08:09 PM
stangerang's Avatar
whoopdy fucking do!
nice mang...... the foci will soon own the streets!
200 points away from a 300
Old Mar 11, 2003 | 05:05 AM
Modular Matt's Avatar
200 SHOT
Thumbs up
Damn a focus with a cam thats kinda cool.time for some spray.who needs a header when you can get a zex kit for the same price
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old Mar 11, 2003 | 07:29 AM
BodyRollin''s Avatar
TRs Iron Chef & Party God
[i] a cam [/B]
bwahahahahahahahahahahahahahahahahahahahahahahahah ahahah...... ok im done, sorry. you think you can handle nessie at the next track day alan?
helping bring peace to the world, 1 party at a time
Saggleman: cause lord knows theres nothing i love more than swallowing condoms full of cocaine
