Need Opinions
Ive got a 95 GTS that Im tracking at the Auction. Im pretty sure I can get it for less then $2500 and wouldnt have to rebuild the 2 most major componints (sp) of the car; the motor and tranny. The interior is the same as mine, so that can also be swapped.
-Ryan-
-Ryan-
Got a better idea. Keep the v-6, and get a fox body to play with, go with a 87+ to keep the mas air and build from there. If you look around you could find a good starter car. I am a firm believer that great cars are built not bought. I would love to build up a fox body and drop a 460 in it.
Member Modern Mustangs of North America
http://www.modernmustangs-na.com
Guest
Posts: n/a
This is probably the best route and it will keep your insurance down. That is unless you are hell bent on using the sn-95 chassis.
Originally posted by the anti-rice
Im hell bent on the SN95.
I just dont like the looks of the fox body.
Ryan likes the look of his long flowing sn
J/KIf you can handle doin the swap Ryan Id say go that route.
Good Luck
J/K
Good Luck
Good Luck
Getterdone
-Ryan-
-Ryan-
