idle surging problem
Old Jun 30, 2012 | 11:44 AM
thundermax's Avatar
blown
Default idle surging problem
I have 93 gt with: f cam, holley systemax intake, 70mm tb, 73mm maf with 19lb sample tube. The car will idle fine for about 3 minutes then will start to rev up and down, and dies. I tried adjusting idle between 700-900 rpm with the same result, my base timing is at 12* Where should I go from here? Thanks
Old Jun 30, 2012 | 12:48 PM
OldMan's Avatar
Donut Killer
Just taking a wild guess, but the IAC might be the issue. You can get one these to help set the idle and hopefully resolve that surging issue...
idle air control adjuster - LRS Search
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Jun 30, 2012 | 01:28 PM
thundermax's Avatar
blown
I have that adjuster, and it does absolutely nothing. the only way i can adjust idle is with throttle plate stop screw
Old Jun 30, 2012 | 05:36 PM
billybro1999's Avatar
sounds like a vacuum problem
Old Jun 30, 2012 | 06:26 PM
OldMan's Avatar
Donut Killer
With the car off, disconnect the IAC, start the car, set the idle, then plug it back in. If that doesn't help with the idle, then yea, that isn't the issue. When I had issues with the IAC, that was the only thing that cleared it up.
On your MAF, is the sample tub on the top side? I have seen that cause issues as well.
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
Old Jul 1, 2012 | 04:55 AM
purple87lx's Avatar
just a single cam hatch
My car did the same thing I just removed the iac and built a delete plate, then set idle with the set screw.
Thatguysstuff
Apr 19, 2007 05:29 AM
Superkaioken
Nissan/Infiniti Tech
17
Aug 10, 2005 06:43 PM
Gary
5
Jul 15, 2005 01:36 PM
MacGruber
May 29, 2005 04:39 PM
quickcivic
Nov 6, 2003 09:32 AM
