99 ls surging idle
ok its a 99 acura integra ls it has surging Idle problem. It has been converted to obd1 by glen at coastal dyno. I was thinking its the iacv but I replaced it and that didnt fix it. no codes being thrown. the idle will stay between 1200 and 1500 rpms. I have no clue if there is any ideas let me know please.
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
The problem could lie in the ignition timing/idle set screw.
Is the ignition timing on the ecu modified in any way?
Is the iginition timing at set to 16.5 deg ?
Have you played with the plathead idle set screw on your throttle body ?
Glen at coastal dyno??? hmmm....
Anywho, are you throwing any codes??? Is your CEL on???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
