Rack Question
I have (what I believe) is a power steering rack from an SN95, it is on a (let's say) 93 Granatelli K-member, mounted on the FOX. I'm using 99 spindles (and brakes) on the car, the issue is this.
It look like I will run out of adjustment on the tie rods before I have the correct toe-in on the spindles. Does anyone make a longer tie rod, tie rod end, or do I just fab up my own hiem joint tie rod end and aluminum sleeve?
