need help what would casue this ?
Old Jun 27, 2011 | 06:23 PM
  #61 (permalink)
st pete chad's Avatar
this is all the info from the guy off the turboforums that said he knows how to read the spark advance chart.im reading it over and over trying to understand it all.
Load is the engine load. 1 is 100%(most you can achieve with a naturally aspirated engine without ram air or something). Basically multiply the numbers by 100 to get the actual. Anything below 100% means you have vacuum in the engine. Anything above 100 means you have positive pressure(boost) inside the intake manifold. You just match up the load number with the rpm you are running to find the spark. Anything not specifically listed is determined from other values. So in between all the numbers you see, the computer just draws a straight line connecting the info. Right now the ambient pressure is around 14.7 psi, that's considered atmospheric pressure, it varies slightly when you change elevation. Anything above that is referred to as boost. So 1 psi of boost in your engine is really 15.7psi TOTAL. To get the amount of boost(roughly due to changes in elevation) just multiply the load number by 14.7. This is all psi. 100kpa is the same as 1 in the load value. 200kpa is 2 in the load value. The number you get when you cross reference load and rpm is the actual timing you are supposed to be running
The timing is set to make decent power until 6500 rpms below 8 psi. Above 8 psi the timing falls off a lot. If you add 4 degrees by twisting the dizzy then it will be four degrees above what you have now ASSUMING CURRENT TIMING IS AT 10. All those calculations are done by the computer thinking the base timing is at 10. You don't need to keep the spout out once you twist it... the problem is you will be running 22 degrees timing under boost at 8 psi. That might be enough to detonate...
Looking through your recent posts, if it's the thing you mentioned about hitting a brick wall, the likely culprit seems to be spark blow out. 11.5 degrees timing shouldn't make the engine just stop climbing in rpms.
You have 10.5 degrees timing from 3000 to 4750 rpm at 14.7 psi. If you have close to 13.5psi boost at 3k rpm and up, you are only losing one degree of timing when you hit 4750rpm. One degree shouldnt cause it to dropoff that sharply.
In one of your posts you said you are having issues with the psi dropping. That combined with the dropoff in power seems to indicate that the turbine housing is too small or some other restriction in flow. Assuming you are running the Turbonetics 76mm turbo from another one of your posts, the compressor should have plenty of power left. What size turbine housing do you have? What is the exhaust like after the turbo? Are you running a carburetor? If not what is the intake like other than the spyder intake?
It is low, I believe you should take it to the tuner and have him bump it up some, stuff like this is why I learned to tune on my own. I don't think it will fix the problem of the car falling on it's face though, but it might be. You should get that taken care of FIRST, and I believe the tuner should do it for free, but since you left there with it like that he might not fix it for free... 1 degree of timing ADVANCED should not make the car fall on its face all of a sudden, it should help make more power. That's why I believe it's some form of restriction in airflow
I am assuming you build full boost before 4800 rpm. Correct?
From 3000 rpm-4750 rpm, you have 10.5 degrees of timing at 14.7 psi, you have a little more at 13.5 psi. When you hit 4750rpm, at the same boost pressure, you GAIN 1 degree of timing. If you ran 8 psi you would have 18 degrees of timing, or if you don't build boost until 4750 rpms it will drop from 18 to 11 degrees when pass 8psi.
At 8 psi(right at 1.5 in the load row) from 3k-6500rpm you have 18 degrees of timing. But you are running more boost, close to 14.7, so you will be really close to the values in the 2.0 load row(horizontal) under boost. Which means at constant boost pressure of around 13.5 psi, if you build full boost before 4750rpm, when you hit 4750rpm you GAIN 1 degree of timing. The chart pulls timing as boost gets higher, but I'm sure you have full boost by 4750 rpms, which means you aren't losing any timing at 4750, you are gaining 1 degree
[IMG][/IMG]
357w s475 turbo Hughes powerglide
Old Jun 27, 2011 | 06:24 PM
  #62 (permalink)
Originally Posted by GNs-r-slow
What are you using to pull timing?
hes pulling timing with the diablo chip based off the load
[IMG][/IMG]
Old Jun 27, 2011 | 06:25 PM
  #63 (permalink)
The same one that dyno'd it for you?
yea the same guy that tuned it
[IMG][/IMG]
Old Jun 27, 2011 | 06:30 PM
  #64 (permalink)
GNs-r-slow's Avatar
Bondsman
Open pockets and make it rain!!!
Old Jun 27, 2011 | 06:42 PM
  #65 (permalink)
lol i wont spend anymore money getting it tuned by him im not talking shit about him i just not happy with the tune.not to mention when you let off the gas it pops alot which it never did before
[IMG][/IMG]
Old Jun 27, 2011 | 06:46 PM
  #66 (permalink)
GNs-r-slow's Avatar
Bondsman
Not this guy particular, anyone really!
Old Jun 27, 2011 | 06:54 PM
  #67 (permalink)
you are 100% correct ill keep the anderson pms and learn to tune it myself.i have had a few people tell me to take it to sniper but im at the point where i dont want to spend another 500 on sometyhing that might not be any better
[IMG][/IMG]
Old Jun 27, 2011 | 06:56 PM
  #68 (permalink)
GNs-r-slow's Avatar
Bondsman
For the $1k you'd have in it, you could of put a used Fast or similar technology on it
Old Jun 27, 2011 | 07:06 PM
  #69 (permalink)
i was just thinking that
[IMG][/IMG]
Old Jun 27, 2011 | 09:04 PM
  #70 (permalink)
EsCoRtLvR's Avatar
Escort Connoisseur
The guy in the post you clipped onto here has it to a T(no pun intended). The timing is an issue on the optimal power, but you have another issue at hand such as spark blowout, or what I had posted up could be a possibility too. I would'nt mess with the timing until you get the mechanical issue resolved. With a setup like yours I would not be using a diablo chip to do any part of this. IMO a nice Megasquirt speed density system would be perfect if you want to dabble "yourself" in tuning, they have plenty of plug and play kits for these cars. Just my .02
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
