need help what would casue this ?
from what he said once it hits 8psi it goes from 18 to 11.5 timing.just look at the spark graph.now that he showed it to me i understand it but im not 100% sure they would stop it from making power past 4800RPM
yea i hear most 93 is like 91 as for the A/F i was told by a few diffrent people that 11.8 is really safe.as for the tuner yea im sure hes trying to make more money off me as for working on the car i dont have anyone work on it just me a friend cause i dont trust many people to work on it and i didnt really trust anyone to tune it but i had no choice.
I run mine at 10.8
NEW Machine
89 Mustang GT
9.040 at 153.13 1.502 60ft Hoosiers 275/60 Jan 2012
True-Street trim
348, 88 t4 .96, pump gas
www.alkycontrol.com
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
That needs to be higher. Timing that low will lose a lot of power. Put some 100 NL in the tank, put timing to 18 degree's above 4800 RPM's and fatten it up a little to lower 11's.. should pull clean. If it doesnt.. then its springs.
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
Do you know what your timing is at off boost at it's highest point?
Do you have a wideband in the car? Or a way to watch the AF.
john
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
i just got off the phone with the tuner and he dont want to add anymore timing into it
yes i have a wideband to be honest with yo i have no clue what timing is off boost
The same one that dyno'd it for you?
