need help what would casue this ?
Old Jun 26, 2011 | 09:42 AM
  #31 (permalink)
st pete chad's Avatar
Originally Posted by Brutal Metal
You seem to be focusing on spark, what about your fuel system? Have you done any logs on the dyno of the pumps duty cycle %?
Is your rail pressure holding steady at 5K?
the fuel is fine its 11.8 all he way and im guessing its holding according to my fuel pressure gauge
[IMG][/IMG]
357w s475 turbo Hughes powerglide
Old Jun 26, 2011 | 10:13 AM
  #32 (permalink)
Stoopid Wendy's Avatar
see dick run
I wouldn't run it at 11.8, your just asking for trouble on pump. I don't see how someone can tune a car to "stop" making power at a set RPM. I bet it's a mechanical/ fuel problem stopping it at 4,800.
Are you running an air filter? Sounds stupid but we had a filter that was too small and it did the same thing. After that, we never ran one.
You also have to factor boost pressure on the intake valve, the pressure on the valve acts like a week spring. You want to run alot of spring pressure on the closed side, but you can't have too much on the open side or your collapse the hyd lifter.
And when we did the 610 it was with the 80mm turbo on the 363ci. (we couldn't break 525 with the 70mm it was too small)
You can't mistake fuel pressure for volume.
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
Old Jun 26, 2011 | 10:45 AM
  #33 (permalink)
GNs-r-slow's Avatar
Bondsman
Is you FP rising 1:1 with boost? Also where is you hoses running from/to for fuel pressure and wastegate?
Old Jun 26, 2011 | 11:11 AM
  #34 (permalink)
john
no we took off the filter and going to put a screen on it.as for someone tuning the car to making power something is not right cause he ran the car on just the jgs wastegate and he said it pulled all the way to 6200 andwanted more and i told him im not going past 6200 that was with 18total timing.then when he put on the manual controller he said clutch was slipping when its not you can see in the video it stops at 5000RPM.so after he was done he put my AEM controller back on and was starting to unstrap the car.i told him no dyno it with my AEM controller.so whats weird to me is why on the wastegate did it pull clean to 6200RPM and now with the controller on it and wont make power past 4800RPM ?
as for him tuning it for it to not go past 4800RPM maybe hes pulling alot of timing on the top end which is why it wont go past 4800.
only reason im saying this is because the other day i cecked timing and with spout out it was at 8degree so i took it up to 12 with spoutout and now it will go past 5000RPM but you can feel its loosing power
[IMG][/IMG]
Old Jun 26, 2011 | 11:15 AM
  #35 (permalink)
john
whats wrong with 11.8 A/F i was told thats good for a EFI turbo car
[IMG][/IMG]
Old Jun 26, 2011 | 11:26 AM
  #36 (permalink)
see dick run
Do you know what your total timing is now under boost?
The way the stock computer works is that if you leave the spout out , it can't control the timing anymore, if your car is still set up that way, I'd pull the spout out and set the timing at 18-19*, leave the spout out and go drive the car and see what it does. It will be piggy down low but should be fine under boost.
john
Old Jun 26, 2011 | 11:38 AM
  #37 (permalink)
see dick run
For what your wanting to do... street car/pump gas i wouldn't trust the fuel around here. Your not after every last drop of HP, so to fatten it up a bit will only make it safer. Alot of this is new to you, things can go bad fast. I know cause i've been there, turbos are a shit load of fun but there is alot going on.
Just take a step back and look at what your doing, Sounds like your getting pushed around by your tuner, you NEED to understand what's going on with your car and he NEEDS to take the time for you to know that. Our you need to find someone else to work on your car.
john
Old Jun 26, 2011 | 03:03 PM
  #38 (permalink)
john
im guessing 13.5 which is what the tuner told me as for as timing with spout out i didn that the other day and set it to 20 and it didnt feel any diffrent but when i pulled back into the house the headers were glowing red which has never happened before.
[IMG][/IMG]
Old Jun 26, 2011 | 03:09 PM
  #39 (permalink)
john
yea i hear most 93 is like 91 as for the A/F i was told by a few diffrent people that 11.8 is really safe.as for the tuner yea im sure hes trying to make more money off me as for working on the car i dont have anyone work on it just me a friend cause i dont trust many people to work on it and i didnt really trust anyone to tune it but i had no choice.
[IMG][/IMG]
Old Jun 27, 2011 | 04:20 AM
  #40 (permalink)
herrcomestrouble's Avatar
Who put your cam in? Did they degree it? Or just " dot to dot"??..... again if you feel 11.8 a/f is safe have fun. But go ahead and start building another shortblock with better pistons ect...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
