HELP! Likely Culprit for current draw? Garaged Cobra!
Old Nov 20, 2010 | 12:05 PM
Brutal Metal's Avatar
Default HELP! Likely Culprit for current draw? Garaged Cobra!
Something is draining my battery if it sits for more than 5 days? I've had it tested twice and it checks out fine, my Cobra isn't a daily driver anymore just maybe once a week for a 10 mile cruise, is this common? Do I need a trickle charger or something? The guy at AutoZone talked about testing for Millivolts after the positive post is removed from the battery for about an hour?
SVT Cobra-Teksid.020(284ci)
Stock HCI/Forged Crank
Manley Pistons & H Beam Rods
Polished Vortech V-2,GodSpeed SpecV Intercooler
MPH Powerpipe,60's,Twin Aviator's,Kenne Bell BAP
Reichard 3.1,SCT BA-5000,ProCharger Pro-Flow BPV
Auto Meter Z-Series Gauges,Mac O/R H & 2.5 DuraBlack CB
Vogtland 1.6, MM CC Plates,Steeda Tri-Ax,Billetflow IRS Brace
Vortech Intercooler Fabrication Joe Bonczek/Custom Piping
SCT Tune Rob Wells@ Ford Speed Racing
Old Nov 20, 2010 | 01:50 PM
fuelie327's Avatar
remove the positive terrminal and wait about an hour for everything to go into sleep mode. Hook up a test light between the cable and the battery terminal and star pulling fuses until the light goes out . That will tell what circuit to start further testing
Old Nov 20, 2010 | 03:31 PM
Largo 5.0's Avatar
Coming Soon
Potentially the alarm system?
Old Nov 20, 2010 | 11:25 PM
The only alarm is the factory PATS... When I tried to start it the other day the dome light etc.. worked but the starter just clicked, the week before it was Totally Dead, the remote wouldn't even unlock the door?
Old Nov 21, 2010 | 01:38 AM
GNs-r-slow's Avatar
Bondsman
What kind and how fresh is the battery. In my experience Red Tops Optimas are the worst! When I had my GN it sat on time for 2 mos in the garage and it would fire right up. Run / drive it for a while to recharge park it, less than a week it wouldnt start. Trickle charge for a couple days, start / run it, the NEXT day, it was done wouldnt do anything. I had several Red Tops do this over a 2-3 year period
Old Nov 21, 2010 | 07:00 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Don't let it sit so long....
Fixed!
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Nov 21, 2010 | 07:13 AM
Stealth Mode's Avatar
Still CREEPIN
Tis' true. There badass batteries, but when they die, THEY DIE. No notice, no warning.
Just get one of the Braille Batteries! It'll fix ya' right up and then you never have to worry about it again!
TurboRAM Member #5
24psi & Stable
GET SOME
Old Nov 21, 2010 | 07:47 AM
fuelie327's Avatar
I would at least make sure it doesnt have a draw before you condemn the battery
Old Nov 21, 2010 | 11:47 AM
Thanks fuelie, like I said it's been tested GOOD twice in the last month, it's a Duralast RedTop! I'm gonna do some voltmeter tests tomorrow to pinpoint the issue!
Old Nov 21, 2010 | 09:10 PM
Largo 5.0's Avatar
Coming Soon
Worst case scenario, bring it by my work and we will amp it down. See if, and how much it is pulling when its off.
