GT40P worth fixing up?
Old Oct 29, 2010 | 07:00 AM
cuddy87's Avatar
How much do you think a set would cost if its already had the work done to them?
Is there a perfect set of parts ( 500hplx ) said "Matched to the right combo and a power adder, they will make enough power to break a stock block!"
You speak of cam, intake manifolds, and headers when you say THE RIGHT COMBO??
Does anyone know how much it costs to machine heads?
What parts would I be looking at to buy?
Maybe I need to try to find another set already done the work to em.
Stay Fresh ... As GOLD
Old Oct 29, 2010 | 07:11 AM
500HPLX's Avatar
Well when I look to set up a combo, I start with how big is the motor? OK here it is a 302. Heads, GT40 P likley flows around X cfm at X lift. So then match a cam with that flow and a power band in the rshared_pm range I want to run. Intake will vary somewhat (NA or forced induction).
I ran P heads w/ a "mild" Comps XE264HR. .512 lift was right at where the P's flowed at their max. Idle and vacuum were great. I orginally had a 93 Cobra intake and it all matched up perfect. For a mild DD combo it was hard to beat.
Then I got greedy and added a short runner intake and the Novi and things were never the same. It had throttle response like a damn bike then.
Old Oct 29, 2010 | 07:36 AM
cuddy87's Avatar
On your heads, what valves, springs, rockers and rods did you end up using?
Ok Im understanding the idea of combos now, thanks!
WOuld you suggest ford racings F cam a good match for P heads? stock heads?
What headers do you run? I heard Ford Racing headers fit the spark plug placement.
Old Oct 30, 2010 | 08:49 AM
500HPLX's Avatar
They came with stainless 1.94 intakes and 1.58 exhaust, dual springs for .550 lift cam. I cant remember the spring rates but they matched the Comps cam I decided to run perfect. It has Cam Dynamics 1.6 roller rockers, stock push rods, Ford replacement roller lifters and a Cloyes timing chain. Cam is installed straight up.
The F cam is a good all around cam. I think the Ford cams have mild ramp rates. That is why they match up to the so, so springs Ford Racing uses on their heads. I like the Comp Cams XE roller series better.
I ran Ford Racing stailnless headers. They fit, but I still cant use a socket and ratchet to change the plugs. I use the socket and a wrench. A couple are always a PIA.
