Front brakes and wheel problem help
Old Oct 30, 2010 | 11:00 AM
Razor's Avatar
Default Front brakes and wheel problem help
Bought an 89 GT. Has the tubular K member and has the Cobra brakes 5 lug. 90/10 lakewoods and 14-175's springs. Wheels currently on the car are the Cobra R's 17's.
Here's where it goes south.. I want to install these Weld prostars I bought assumming they fit .. the problem is wheels hit calipers.. and stick out hitting the fender .
What is the solution to running prostars on an 89 Mustang.
What size tires on 3.5 welds. I beleive the answer is a 165r15.
Based on what I can gather the control arms are of different lengths on the 87-93 and 94-04. And there seems to be an issue with the the spindles of the 94-95 era and the 96-04.
So my question what do I need.. brakes, spindles, and control arms.. to use Prostar 3.5 wheels on my 89 Mustang Without going the Aerospace/Strange/?? $800+ deal. How can I tell what control arms I have?
Thanks guys.. always something.. Always learning..
NEW Machine
89 Mustang GT
9.040 at 153.13 1.502 60ft Hoosiers 275/60 Jan 2012
True-Street trim
348, 88 t4 .96, pump gas
www.alkycontrol.com
Old Oct 30, 2010 | 11:21 AM
GNs-r-slow's Avatar
Bondsman
Sticking out could be the K-member, A-arms, or/and spindles. What year spindles where used and what brand K-member?
Pics of arms would help. Sounds like you have SN95 spindles
Old Oct 30, 2010 | 11:26 AM
Razor's Avatar
Originally Posted by GNs-r-slow
Sticking out could be the K-member, A-arms, or/and spindles. What year spindles where used and what brand K-member, stock arms or tubular?
Its all tubular.Its black if that helps
How can I tell what spindles I have? When the rotors where pulled off it had a reluctor on the back. Guess 98+? Brake calipers say "COBRA"
Since I didnt make the conversion.. I have the slightest idea whats on it.
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
Old Oct 30, 2010 | 11:38 AM
Stoopid Wendy's Avatar
see dick run
A QA-1 k-member sets the wheels out 1 inch and forward 1 inch, i have spindles off of a 95 mustang with the dual aluminum calipers and i have to use a 1/2 inch spacer to clear the brakes. Post a pic of the k-member.
The tires for a 3.5 rim are 165sr15 or 165/80r15 same tire size.
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
Old Oct 30, 2010 | 11:39 AM
GNs-r-slow's Avatar
Bondsman
Sounds like a Qa1 with SN-95 spindles...this brand moves the wheels out and forward.
Old Oct 30, 2010 | 11:40 AM
GNs-r-slow's Avatar
Bondsman
john
You TREED me
Old Oct 30, 2010 | 11:43 AM
see dick run
Sleeping again?
And if you have 96-04 that's another 1/4 on each side, adds up quick
john
Old Oct 30, 2010 | 11:48 AM
Razor's Avatar
What part of the K-member do you want to see pixs of?
You guys are awesome.. thank you.
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
Old Oct 30, 2010 | 11:55 AM
see dick run
Here is a pic when i did the wife's car and is a QA-1
If this looks like yours, you can buy a-arms that are shorter.
john
Old Oct 30, 2010 | 12:02 PM
Razor's Avatar
Hope these help?
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
