cheetah shifter/ c4
Old Oct 12, 2010 | 05:57 PM
GNs-r-slow's Avatar
Bondsman
This is what the two Cheetah shifters I had came with.
Old Oct 12, 2010 | 06:44 PM
DrDirt's Avatar
Team Geritol Racing
Here's the one I have. no numbers on it and the bolt is missing but it's just a bolt and nut. I can probably find one lying around that will work. $15
YO! Barry! You LOST!
Old Oct 12, 2010 | 06:52 PM
st pete chad's Avatar
so the one on ebay i listed up is the one you had? did it shift fine.steve at CRT told me to make sure its the right one cause some of them will allow it to get stuck in between gears
[IMG][/IMG]
357w s475 turbo Hughes powerglide
Old Oct 12, 2010 | 08:53 PM
franktf's Avatar
Turbo Action shifters for the Fords have there own specific shaft/lever and pan bracket(the B&M cable bracket will not hold the morse cable that Turbo Action uses)..... The Turbo Action one unscrews, none of the factory ones do(you needed the shaft from the other trans)..... Here is a pic from there site instructions.....
Old Oct 13, 2010 | 04:49 AM
yea the pic you listed is how my other c4 looked.the new one the shaft is way diffrent.i have looked for the new shaft like the one in the pic but im not able to find anyone that sells it.
[IMG][/IMG]
Old Oct 13, 2010 | 04:17 PM
GNs-r-slow's Avatar
Bondsman
We just used the other one you posted when Cody put the C-4 in his car.
I works fine. This shifter set up came from Mikey's turbo Crapi
Old Oct 13, 2010 | 04:52 PM
  #17 (permalink)
this is the one you guys used? everything lines up fine?
TCI-418400 Shift Lever Steel Ford/Lincoln/Mercury C-4/6: eBay Motors (item 330482627094 end time Nov-08-10 00:27:24 PST)
[IMG][/IMG]
Old Oct 14, 2010 | 01:29 AM
  #18 (permalink)
GNs-r-slow's Avatar
Bondsman
Y-e-s-s-s!!!!
Old Oct 14, 2010 | 04:05 AM
  #19 (permalink)
Y-e-s-s-s!!!!
thanks
[IMG][/IMG]
Old Oct 14, 2010 | 01:42 PM
  #20 (permalink)
herrcomestrouble's Avatar
If you are allready buying a new shifter arm. Get the 1 with the slot all the way up and down the middle. it will make setting it up and adjusting the shifter alot easier. I will try to find a link.
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
