cheetah shifter/ c4
ok so i was putting in the new ART CARR C4 the other day and sold the c4 that i got from kevin.so my question is i was going to hook up the cheetah shifter part# 70013 i noticed the shifter lever would not go on to the ART CARR c4.the old c4 the shifter lever was threaded and the ART CARR is not so do i need to replace the shifter lever inside the tranny or what.i listed some pics below to see what i was talking about.if anyones know what i need to do to get it working let me know.thanks
yes, you need a lever that "clamps" onto that shaft. It will have a flat part, that corresponds to the flat part on the shift arm on the transmission. Also going to need a custom cross-member, A drive shaft spacer ect.... Also dont forget to notch the bellhousing 33 times
edit your running turbo, dis-regard that last sentence.... lucky bastard
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
is this what everyone is talking about?
TCI-418400 Shift Lever Steel Ford/Lincoln/Mercury C-4/6: eBay Motors (item 330482627094 end time Nov-08-10 00:27:24 PST)
No , this. 1964-1977 Mercury Comet Shift Lever - B&M
Notice there is also a bracket, it holds the cable end.
