How do I solve THIS problem?
They are both out of the car. They both have full pans too.
So it's going to be a bitch because I have to try to do it all in the rain and on the ground. No table for me.
I need a general consensus here.....Will the arm that Dr. Dirt has WORK in this application? If it will, that sounds a LOT easier.
that linkage will not work with the stock shifter,as it is not the same length of the stock rod.
you also need to make sure the tailshafts the same driveshaft may not fit but you can swap it from the broken one
it has been awhile since i did one also but i dont remember it being that hard...pull pan on broken one first abd play around with it its already broken..its not that bad to do...
I think he was simply using it as a trans plug. LOL
