$100 bounty or more
$100 bounty or more
I changed the carb (650 DP) mounted the holley blue pump (on rear bumper) checked fuel pick up in tank, mounted a brand new regulator. Still have eratic fuel pressure (old gauge might go get new one). car idles ruff then fine then stalls. I'm tired of messing with it. Anyone that can come to my house and fix this beotch I will be glad to pay them and I'll even through in lunch. (813)382-0209 in live in seffner off of us92 between kingsway and McIntosh road.
The gauge in the dash isnt the fuel pressure, its the level... Put an actual fuel pressure gauge on it and see what it truly is. It only takes 6.5psi of fuel to make a carb car run...
You can get the gauge from any NAPA or CarQuest. Attach it with a peice of fuel line to the oppesite side of the regulator were the fuel line is going to the carburator, start it and see what the pressure is. Should be no higher than 8psi and no lower than 4psi. Sounds like the fuel PSI is uber low. Its just starting and running off that little amount of fuel thats loaded in the carb and when it runs out it shuts off.
TurboRAM Member #5
24psi & Stable
GET SOME
Did this carb sit for a while before you used it?
General Stonewall Jackson has been quoted saying that when the time of war comes,
“My advice is to draw the sword and throw away the scabbard".
Barse... Do you want help or what? PM'd you my number and still havn't heard from ya. I'll be in the area today before I take off for work tonight.
TurboRAM Member #5
24psi & Stable
GET SOME
Sounds like the floats are set wrong and possibly the needle and seat are malfunctioning.
How long did this holley sit before putting it on your car?
I live right up the road from you by palm river road and 78th st. If you're free tomorrow, I can check it out for you.
give me call 95coBraSVT. I go to work at 2. I can do it anytime before that
I just got carb friday. usedfrom stangitman289. I texted him to find out how long it was sitting.
And this will cause the pressure to act like that? Do I need to plug off the return line to the tank?
I need a number to call. My number is 813-447-8274. I can be there tomorrow morning around 9:30 or so.
