What causes this?
Old Mar 1, 2010 | 07:46 AM
95coBraSVT's Avatar
banana republic
Default What causes this?
While driving a 92 Lincoln Town car with the cruise control on, it suddenly drops into passing gear and back out again....Turned off the cruise, and it did it again. Slowed down, and it still did it....This was at about 77 mph. I was not on any hills or anything which would cause the car to slow down at all...It just suddenly dropped into passing gear.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Mar 1, 2010 | 08:00 AM
Hurstmeister's Avatar
Gremlins,..
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Mar 1, 2010 | 08:43 AM
GNs-r-slow's Avatar
Bondsman
do those have a TV cable? Sounds like it needs adjusted
Old Mar 1, 2010 | 08:10 PM
95coBraSVT's Avatar
banana republic
I think so...I guess it's time to take it to a shop, because I KNOW I don't know how to adjust those properly. LOL
Hurst, gremlins...Thats good.
Old Mar 1, 2010 | 09:12 PM
500HPLX's Avatar
Default Gremlins!
Those little bastards are hell to get rid of.
You know they cause hemroids too!
Old Mar 1, 2010 | 09:34 PM
GNs-r-slow's Avatar
Bondsman
The adjustment is done at the throttle body...forgot the exact procedure, but its real easy, google it
Old Mar 1, 2010 | 09:42 PM
GNs-r-slow's Avatar
Bondsman
Here ya go... Ford AOD Transmission
Take your time and do it right. If it doesnt shift right, STOP and do it again! Otherwise you'll be looking for a new AOD
Old Mar 1, 2010 | 09:44 PM
GNs-r-slow's Avatar
Bondsman
Before you jack with the TV cable, check and make sure you cables, daiphram, ect isnt hangin up on the cruie control. HTH
Old Mar 3, 2010 | 07:13 PM
95coBraSVT's Avatar
banana republic
Ok, finally getting to this again. I checked, and no cable attached to the throttle from the transmission. Only one from the pedal, and one from the cruise module.
Old Mar 3, 2010 | 08:22 PM
If I remember correctly,. .the 91 had a 4.6 but had the AODE and it used the small block ford bolt pattern. But in 92 they went with a different fully electronic transmission with the 4.6 bolt pattern. The 4R70? Go on Autozone and register,.. then look up the tech manuals for the car.
AOD used a TV cable like the GM 700R4's did. The AODE I know nothing about,.. and even less about the 4R70.
Hurst
