Help with wheel backspace
Old Feb 5, 2010 | 07:48 AM
00siboy's Avatar
Bone Stock
Default Help with wheel backspace
Ok so on the Cobra, I am running a 15x8 Prostar with a 5.5" bs. I have a 325/50 on it and I have to use a small spacer to clear the back of the wheel to the caliper. I am looking at a different wheel that is a 15x10 with a 6.5" bs, but I don't want to jump the gun if there will be no difference. The tire is hitting the fender at times and I want to pull it in a bit. Anyone have any advice on what to do? And for clearing it up, the tire doesn't stick out of the wheel well, but sits relatively even with the fender.
-Darren
03 Cobra Vert: Whipple, Lt's, H-pipe, SRA, 325 MT Dr's, more bolt-on's - Weekend Beater
88 Mustang Coupe: Gutted - Project
Old Feb 5, 2010 | 10:52 AM
GNs-r-slow's Avatar
Bondsman
15x8 is too narrow for a 325. I have 15x10's with 6.5" BS on a Fox..It will def clearon a SN or new edge
Old Feb 5, 2010 | 11:00 AM
00siboy's Avatar
Bone Stock
Is your car lowered Tommy? What setup are you running for your rear suspension? I have drop down brackets with the Lakewood southside LCA's and it drops the height about an inch. I think those might be changed because that is killing my clearance. That along with my coilovers being set too tight is not letting any weight transfer to the rear.. I am debating between a 275/60 and keeping my 15x8's or going 15x10 and doing the 325/50 again. I just know I need to stick with the 28 or I'll top out 4th before the traps in the 1/4. I trap mid-low 3rd in the 1/8th right now.
-Darren
Old Feb 5, 2010 | 01:08 PM
GNs-r-slow's Avatar
Bondsman
Southsides dont lower the car persay, brackets are to change the pinion angle. You must have lowering springs. Yes my car is lowered I have coil over rear suspension
Old Feb 5, 2010 | 01:23 PM
00siboy's Avatar
Bone Stock
I have Lakewood 50/50's, UPR Coil Overs with 10-150 springs, Lakewood Southside lower's with the reloc. braket and tubular non-adjustable uppers. I have the coilovers up tight to keep the tires from rubbing, but when I was trying to launch at the track, it wasn't letting weight transfer to the back.. Maybe some adjustable uppers to correct pinion angle?
-Darren
Old Feb 5, 2010 | 01:44 PM
stealth gt92's Avatar
how about putting the whole setup in your foxbody and low 10 sec ets in the 1/4 how does that sound darren?
Old Feb 5, 2010 | 04:09 PM
bvh's Avatar
bvh
he SHOULD have a 10sec car now. why would he swap everything to a ugly foxbody?
Old Feb 5, 2010 | 04:59 PM
cause he has a coupe sitting it would be a MUCH better base for what hes trying to do than that cobra.
Old Feb 5, 2010 | 05:21 PM
00siboy's Avatar
Bone Stock
Lol why would I do that. Brian is right. The Cobra ran great, but even better if it would hook properly. Maybe the pinion angle is off.. Oh well, it's to the drawing board this weekend.
-Darren
Old Feb 5, 2010 | 09:14 PM
bitemark46's Avatar
Got traction?
SSM's technically can lower the ride height. If the rear pivot point of the LCA is moved down an inch that means that the spring purch (since attached to the LCA) will also be lower than its original position. Being its not on the end of the arm it may only lower it 3/4" or something.
SSM will also increase your AS. This means it will hit the tires harder but can unload quicker if you don't have a loose nose to keep the load all through the 60'. You also need adjustable uppers to dial in your PA. But you may want to also look at UCA's that relocate the rear pivot point. This will move your IC back and increase your AS.
Have you ever plotted your suspension?
-Mark
98' cobra
