what do you all think?
Old Dec 15, 2009 | 04:36 PM
Stealth Mode's Avatar
Still CREEPIN
There are tons of big block 460-557ci Fox bodies! Never been to an NMRA event? Lol
TurboRAM Member #5
24psi & Stable
GET SOME
Old Dec 15, 2009 | 05:00 PM
460 TZILLA's Avatar
THROTTLE STEER
Originally Posted by Stealth Mode
460 FTW! 460T-Zilla broke the dyno in his double carb'd '73 Mach 1 with a close to stock 460 with an assload of spray.
460's in a fox chassis car = Ready to pull the gates off hell when it catches traction.
actually bottom end was stock, ported DOVE heads,1:7 crane gold rockers,
dyno Don Nickelson Tunnel ram with twin 600 edelbrocks..NO SPRAY and we broke the dyno at 48 mph at just under 500 horse with it shifted to third. Dyno guy had it in second thought it was third and when it shifted it jacked the dyno all up..took them an hour to fix the dyno and fryed my coil in the safety mode of the dyno shutting off.......enclosed pic of said car..
Talk softly but Drive a big block
Old Dec 15, 2009 | 05:12 PM
460 TZILLA's Avatar
THROTTLE STEER
Originally Posted by 302GTS
What type of torque curve does a 460 offer? And if they're such a 'god among motors', so to speak, how come more people aren't resorting to bbf swaps rather than a Dart based 351 or something?
Because too many false rumors about how heavy 460's are
460's don't do great on fuel and it would be costly to find a transmission with overdrive to hold up against all that torque making it highway friendly..Most peeps use a built C6 to keep costs down..
I have an 85 mustang GT Ttop, caged,mini tubbed,460 C6 with nitrous I'm in the process of building. weight will be 3000(car only) cost of complete project will be about 6 grand and quarter times will be high 9's and still retain street driveability(legal)
Still CREEPIN
Absolutly sickening!! Put a solid $1500 in the engine and you will have more than a tq demon and possible more than the Fox chassis can handle without the proper bracing. Cant wait to see what the t-top does!
TurboRAM Member #5
24psi & Stable
GET SOME
Old Dec 15, 2009 | 05:13 PM
**CHRIS**'s Avatar
Called the amba lamps
RedVert (Stephen) on here has a very nice white Capri for sale for cheap.
Old Dec 15, 2009 | 05:52 PM
rotarykidd's Avatar
ROTM February 2013
Personally I'd stick with a 351w based motor... I just don't see how the 460 is worth it when you can make equal power (IIRC) on, say, a 408 stroker. If you're planning on boosting it anyways, why go for a 460 when you can just build a decent 351 and throw the boost at it then.
this. my freind and i built a 408 using a 351 block, 400 crank, and then bored. made some pretty good power out of a junk yard built n/a motor.
Old Dec 15, 2009 | 06:19 PM
  #17 (permalink)
Still CREEPIN
Stock D0VE headed 460 on a 250 shot will eliminate any stroker Windsor. Problem is getting all that TQ to the ground, and when you get it to the ground, praying that the 700ft/lbs of TQ dont take the driveshaft and shove it up through the tunnel.
http://wiki.answers.com/Q/Horse_powe...v8_ford_engine
TurboRAM Member #5
24psi & Stable
GET SOME
Old Dec 15, 2009 | 06:40 PM
  #18 (permalink)
rotarykidd's Avatar
ROTM February 2013
the f3 460 has larger intake valves/ports then the d0ve iirc
Old Dec 15, 2009 | 07:14 PM
  #19 (permalink)
ruler's Avatar
97 gt
i got a 460 for 100 bucks tore apart ready for go fast parts. Has all accessories and crank is polishable (although I would buy a stroker kit) located in palmetto
Old Dec 15, 2009 | 07:21 PM
  #20 (permalink)
Still CREEPIN
Darby, I'll trade you a brand new 8000BTU/HR window a/c unit for it... Im talking brand new in the box. Bout two years old.
TurboRAM Member #5
24psi & Stable
GET SOME
