SBF Compression woes
Old Apr 2, 2009 | 10:09 AM
  #31 (permalink)
Hurstmeister's Avatar
Originally Posted by 351coupe
But just for some info,Hurst,400+ci and twin turbo's will not be cheap to make run good.Yes you can put junkyard turbo's on it and it will run,but not like it would with one good turbo.And with a big motor if you do your homework a big single will spool pretty quickly.
I'm going to do a 392ci with a 3.85 stroke.
This combination will allow me to zero deck it with a 'normal' thickness head gasket for good quench and still get me the 8.4 - 8.5 CR I am looking for.
I am not aiming to push more then 15 PSI through the motor,.. with 10 - 12 PSI being the main focus for 93 octane pump gas.
With 392ci at 15 psi this should net me 800+ torque and 600 - 700hp. That is my goal.
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Apr 2, 2009 | 10:13 AM
  #32 (permalink)
Originally Posted by bvh
Brian the tuner is running a power stroke turbo . u might want to look at one big turbo off a power stroke or a cummings .
That may be a good direction for me to source out a semi decent 'affordable' turbo. I will try to find out some more info and find who and where they are selling. I've read that those guys were pushing upwards of 90 PSI into 7.3's with the stock turbo.
Thanks Brian,
Hurst
Old Apr 2, 2009 | 10:46 AM
  #33 (permalink)
bvh's Avatar
bvh
not a problem. im all about building on a budget!
Old Apr 2, 2009 | 10:59 AM
  #34 (permalink)
GNs-r-slow's Avatar
Bondsman
Hurst
I was pushing 26lbs on a stock 6.0 with just a programmer and exhaust. I'm throwing this route around myself.
