Tire size / Gear Ratio
Im planning out the final pieces here, I need some advice on Tire size/gears so I can match a TQ Converter to them. Motor should be making right around 500 hp/500 tq. Car is stripped and will not be a DD.
4v 351c
Edebrock performer 351c
Carb is holley 750, If this isn't enough I think an 850 will work well.
built 4v heads
Forged pistons
compression is 11:6
its pretty sinple. your cam is the brain to your engine. with oug vehical weight and cam specs this is a pointless topic if your running a bullshit street cam 4.56s are pointless if your running a monster thats looking for 8000 rpm its a different story.
I suggest you evaluate what you WANT out of the car and decide what cam IE brain your using as your carb , fuel system , converter , gears and tires will be based on this.
Clevelands, especially with the 4bbl heads like 4.10's+. Alot of cars I've seen with 4bbl heads run 4.30 or 4.56's (28in tires) because they dont make no powah down low because of the runner/valve size. Oh yeah, plan on some spray too
