Tire size / Gear Ratio
Old Dec 6, 2008 | 05:22 AM
Hurstmeister's Avatar
Running a 306 with 4.10 gear. Currently running 27x10 ET Streets. But thats what came on the car. I will probably move to 26x10 while still NA on the motor. Will probably move back to 27" or possibly a 28" tire once I start to spray it.
MPH is 109 - 110,.. even though my 1/4 mi ET's are still 13.09's. Aiming for low 12's high 11 et's NA. Once I get that dialed in,.. will be spraying for some 10 sec et's.
Cleveland motors make pretty good torque compared to windsor motors. They breath a whole lot better also. Bigger headers and longer gears then you would with a windsor motor. Think of the Cleveland as a small big block.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Dec 6, 2008 | 05:26 AM
byondevl's Avatar
Made Of Scars
Originally Posted by Badlatitude
its pretty sinple. your cam is the brain to your engine. with oug vehical weight and cam specs this is a pointless topic if your running a bullshit street cam 4.56s are pointless if your running a monster thats looking for 8000 rpm its a different story.
I suggest you evaluate what you WANT out of the car and decide what cam IE brain your using as your carb , fuel system , converter , gears and tires will be based on this.
I have no idea what this car weighs yet. THe only thing inside is a seat, everything else is gone. It still needs subframes and a cage.
Let me look for my cam card.
Old Dec 6, 2008 | 05:29 AM
Originally Posted by GNs-r-slow
Clevelands, especially with the 4bbl heads like 4.10's+. Alot of cars I've seen with 4bbl heads run 4.30 or 4.56's (28in tires) because they dont make no powah down low because of the runner/valve size. Oh yeah, plan on some spray too
I agree mostly,.. but not so much with the gearing except if running a taller 28" tire.
I had a Maverick years ago and ran 2 different Cleveland combo's in it and it made fantastic low end torque compared to the 351 windsor I had in it before. I ran better times with 3.73 gear then I did with the 4.33 and 4.11 I tried previously on that motor. Was also through a 9" rear and C6 tranny if that makes a difference.
Hurst
Old Dec 6, 2008 | 10:39 AM
GNs-r-slow's Avatar
Bondsman
^^^^2v or 4v?
Old Dec 6, 2008 | 10:46 AM
^^^^2v or 4v?
Was a 4v motor that came out of a 71 or 72 Mach1. Had the big valves in it. I dont remember the exact size,.. something like 2.09 or 2.19 IIRC.
Hurst
Old Dec 6, 2008 | 11:13 AM
$hawn's Avatar
lives in a glass house
for drag racing? 1/4 or 1/8? you have to take in account how many RPMs you going to spin the motor.
500+ hp and you'll easily be in the 10s. lets say 130mph.
130mph with a 4.10 gear and a 26" tire has to be like 7000rpm at the trap.
Old Dec 6, 2008 | 11:28 AM
  #17 (permalink)
byondevl's Avatar
Made Of Scars
1/4m
4.10 with a 26' tire seems to be the advice i'm getting elsewhere as well.
Old Dec 7, 2008 | 04:09 AM
  #18 (permalink)
$hawn's Avatar
im just asking if you're prepared to turn that type of RPM? if not, maybe a little less gear is in order...
Old Dec 7, 2008 | 04:13 AM
  #19 (permalink)
GNs-r-slow's Avatar
Bondsman
26 WILL be too short for a 1/4m. I think it would be outta steam at 1000ft
Old Dec 8, 2008 | 05:50 AM
  #20 (permalink)
byondevl's Avatar
Made Of Scars
If im not mistaken, I think it will be turning around 6800
