lack of power
Old Aug 4, 2008 | 02:32 AM
OldMan's Avatar
Donut Killer
Let us know what you find out...
It kind of sounds like the cat is plugged up, but if you think it is spark related... I would like to know what you find out.
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Aug 4, 2008 | 04:48 AM
DrDirt's Avatar
Team Geritol Racing
Check the cats like Brett said, If they are plugged, the car will fall flat on it's face. I once had a car where the interior of the exhaust pipe pulled away and collapsed causing a huge restriction. That gave the same symptoms too.
YO! Barry! You LOST!
Old Aug 4, 2008 | 12:53 PM
t_rav386's Avatar
ok well i just hooked the computer up to it, and its reading a fuel problem.I dont think its getting enough pressure.It never showed exactly what the fuel problem was caused from.but some fourms i read about the 2000 cougar said the fuel pump goesout all the time.CAn a fuel pump get weak and cause this kinda problem?
Old Aug 4, 2008 | 03:23 PM
t_rav386's Avatar
does anyone know where the fuel pressure plug is at so i can hook the pressure gauge up?
Old Aug 4, 2008 | 04:19 PM
t_rav386's Avatar
ok i found it i screwed it on as hard as it would go and i can crank the car and i got 0 fuel pressure reading from the meter....I know the pressure meter works..DOes any of this sound right?
I can hit the fuel pressure pin and it shoots out a little bit maybe5 or 6 inchs out dosent seem pressurized at all
