cobra vs. gt
Old May 2, 2001 | 08:00 PM
bitemark46's Avatar
Got traction?
ya pretty easy. It has something to do w/ the thermostat on the car. For some reason the fan wouldnt kick on when temp reached 192. Its not bad to the point u have to change the whole radiator. Just the stat and I think an adjustment on the EEC. correct guys if Im wrong. -Mark
98' cobra
Old May 4, 2001 | 03:28 PM
bitemark46's Avatar
Got traction?
Mark
The trannys are about the same strength as the ol T-5. But what I like about the t-45 is the gear ratio. First is 3.37 which pulls hard if u have a 4.10 gear or higher. But on the other side they do have alum shift forks. I wouldnt speedshift a t-45 eventually it will break. Put a aftermarket shifter w/ shift stops and the tranny will last longer. I have had no probs with mine and I have been going to the track for about 2 years. If u shift fast but dont powershift u should be fine. Mark
98' cobra
