Transmisson ?
C-4 in Project Con-Vert has Pa C-4 with MVB and a t-brake. Its the only way Ill run a automatic (MVB) on the street in performance application.
As far as line pressure being too high CAN/WILL contribute to failure. The 200r4 that are in the GN's a same way, but dont think its from the valvebody. Im not a tranny guy but I sure have been through an ass load of them (GN).
Ive HEARD the same thing about running 4.10's /AOD on the street. They dont like the pressure.
Do you know Toby Gant?? He is local to Tampa and KNOWS the AOD's
Ive HEARD the same thing about running 4.10's /AOD on the street. They dont like the pressure.Do you know Toby Gant?? He is local to Tampa and KNOWS the AOD's
He's been around a long time, I remember his LX hatch in a magazine a long time ago probally 15 years ago, that was a bad stang back in the day
, ran a truck intake, with the twin truck 50mm throttlebodies, believe it ran 10:50's then, which was haulin, that car always amazed me. Don't know about his tranny work, but I would bet it is top notch!I've driven many manual valve body cars, some with transbrakes, C4',C6's, T350's, T400's 200R4's never had any problems, like everybody else I call bullshit on that excuse, usually the problem with them failing, is not enuff line pressure. Good luck, hope you find someone that treats you right, I dealt with a similar situation with a tranny before, builder not owing up to his gaurantee, learned a valuable lesson after my wallet was considerably lighter...
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
No worries man but if i'm going out i'm taking some bitches with me.
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
And its funny they moved to 44th street and its a huge shop, I mean its got be be twice the size of the old one.
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
Midget??? I'm 6'1.....
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
