So I did a compression test on the Cougar.
Old Oct 5, 2007 | 06:54 AM
  #21 (permalink)
Suicidal Racing's Avatar
Has V.I.P in HELL!
hey kris did the work on them right?
how does the int line up all the ports line up and shit..check the valves and make sure u didn't crack on or it is hung up..look at the seats.
u are more then welcome to come get my heads and bolt one on joe and see if that fixing the problem..if it dont just give the heads back no big deal..
pm me or call me when u get off work and see this.
Old Oct 5, 2007 | 07:13 AM
  #22 (permalink)
$hawn's Avatar
lives in a glass house
Originally Posted by LS1COUPE
hydraulic lifters will take up any amount of surface that was machined off.
best info here
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Oct 5, 2007 | 04:08 PM
  #23 (permalink)
SmokinS13SR20's Avatar
That ginger...
why did the heads come off in the first place? i have never seen a set of heads that were machined and then the motor didnt have compression because the pushrods were too long. you have another problem.
if you think its the pushrods just back off the rockers two turns and run the compression test again. if it comes back up to normal you have your problem. but like i said i doubt thats were your troubles are.
Heater hose blew, headgasket went, heads turned out to be warped, that's why the heads were machined...
I wanna say they saved 7 off of one of the heads...
I'll try back off the rocker two turns, but it seems like that will allow them to flop around loosely then...
Old Oct 5, 2007 | 04:29 PM
  #24 (permalink)
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Your backing off the rockers for simply a compression test. Do not drive like that, its just for process of elimination.
SUCH IS THE RULE OF HONOUR.
  #25 (permalink)
$hawn's Avatar
.007 is NOTHING
take the rocker arms off, do a compression check again.
Old Oct 5, 2007 | 04:46 PM
  #26 (permalink)
Has V.I.P in HELL!
hes on his way over to get my heads..hopfuly it works out for him..
