Stroker ... 408
Old Aug 17, 2007 | 05:25 AM
  #21 (permalink)
Iraq&Roll's Avatar
Why would one use a 9.2 deck block for a 408? Seems to me that would bring on all sorts of issues starting with the intake. Early 351W's were 9.48? or something and then later were 9.5. Am I missing something or has the Iraqi sun cooked my brain?
Old Aug 17, 2007 | 06:07 AM
  #22 (permalink)
OldMan's Avatar
Donut Killer
Your brain is fine, this is just if someone used a Cleveland block.
Cleveland is block 9.2 (9.213) ,
Windsor block is 9.5 (9.480 before 1973, 9.503 after that).
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Aug 18, 2007 | 04:24 PM
  #23 (permalink)
Subzero's Avatar
Thread Napper
Originally Posted by OldMan
Greg,
$hawn as built a few and he knows how much the little stuff will get you. I have heard him talk about the nightmares he had. I have not built a 408, but these are things I know from reads and friend's cars...
9.2 deck height, so you will need a new lower intake, possibly upper if staying FI,
Headers,
drop motor mounts,
oil pan, pickup, and pump,
new flywheel,
new balancer,
said 408 stroker kit with crank, rods, bearings, pistons, and such,
machine shop time for balance and block work,
front bracket accessories,
distributer,
gaskets for everything,
and the little stuff you never think about until you take the project on.
other stuff that might be....
cam and heads should work, but you'll probably want to match them to the motor,
hood,
head stud kit for any amount of spray or boost,
maybe push rods and new roller rockers for the new motor,
fuel system, like pump, regulator, and lines...??
I think the bell housings are the same for the trany, but not 100% sure,
oh and if your staying FI, injectors and matching mass air.
That is what I can remember at this time of the morning....
If you going to build a motor, than these things would all be changed regardless if your building 302 based or 351...
Old Aug 20, 2007 | 02:08 AM
  #24 (permalink)
OldMan's Avatar
Donut Killer
If your staying with a 302 you could re-use these parts, unless you seen some damage or they were wore out;
headers,
lower intake,
motor mounts,
oil pan and pickup if you had to replace(pretty sure, but may be not the pan),
flywheel,
harmonic balancer,
front accessory brackets,
or distributer.
If you go 351, you have to replace them no matter what.
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
