nitrous question
Old Jul 11, 2007 | 02:42 PM
99cobra281's Avatar
Default nitrous question
ok i just bought 125 dry shot for my 5.0 and i am wondering what are all the little things i need to get or do to the car so i have no problems spraying it....thanks derek
the COUPE that COULD
Old Jul 11, 2007 | 02:44 PM
$hawn's Avatar
lives in a glass house
you need to bolt the driver's seat down first!
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Jul 11, 2007 | 02:51 PM
Badlatitude's Avatar
bbbblllllaaaaaaahhhhhhhh
upgrade it to a wet systen would be a start. Unless your car had honda emblems then id leave it dry and up the shot to 300
Old Jul 11, 2007 | 02:52 PM
$hawn's Avatar
^ yea i didn't see that in my haste...lol A fuel solenoid would be a great place to start.
Old Jul 11, 2007 | 03:53 PM
91Notch's Avatar
Is workin on his car
A dry shot will be fine. Just won't really hit as hard. Change your plugs to a step colder plug, non platnuim, and gap them at about .035 and set the timing at about 10 degrees or so. Would recommend a bigger in tank fuel pump. Everything should be good to go then. What kit are you using? Does it have some sort of regulator that will increase fuel pressure when you use the nitrous?
what type of motor are you putting this on. A 5.0 or a mod motor?
If your putting it on your 99 that uses a return less style fuel system and you really have no mechanical control over the fuel pressure nor any control over the timing.
Old Jul 11, 2007 | 04:08 PM
Steve B's Avatar
brings his heater.
definately add a fuel solenoid.
Old Jul 11, 2007 | 04:17 PM
91Notch's Avatar
Why are you guys so stuck on needing a fuel solenoid. Yes I agree with you wet is better but I ran a 150 dry shot back in the day on my 97 cobra full interior with gears, intake, throttle body, and exhaust and went 7.60's in the 1/8th. I went through a bottle a weekend on that set up for about a year with no problems. So what's wrong with a dry shot?
Old Jul 11, 2007 | 04:27 PM
Just because they work doesnt make them good....
A wet shot you can tune your Nitrous and fuel your putting into the engine specifically .. a dry shot your relying on your car to make up for .... you have alot better odds of NUKING YOUR SHIT. Dry shots are for ricer garbage
Old Jul 11, 2007 | 04:29 PM
Steve B's Avatar
brings his heater.
because if you want to cram a shitload of extra oxygen in your cylinder, it is nice to know there is fuel there to burn it.
Old Jul 11, 2007 | 04:39 PM
91Notch's Avatar
Ok totally agree with you on the tuning issue. But as NUKING your shit I don't believe in that for a small 125 shot. Like I said I ran a 150 shot and even pushed it to 175 on dry with absoulitly NO problems!
