I need some Ford Tech!
Old Jul 8, 2007 | 04:08 PM
Adrenalin's Avatar
Project Fobra
Default I need some Ford Tech!
Where is the best place to weld the bung on my Canton 7 qt. oil pan? The turbo is on the passenger side so obviously on that side but I've heard opinions from the front to the back. If I were to place it in the back, the oil would get to the pickup faster. I have also seen it placed in the front of the oil pan.
Also, where should I measure from to determine how high to place the bung?
Thanks TR Ford Tech!
Terry
Click - FQuick
flickr
Old Jul 8, 2007 | 04:24 PM
Duceanahalf's Avatar
is doing your girlfriend
id put the return near the front of the pan, that way when the hot oil returns to the pan it is not going to be picked up immedetly.
Old Jul 8, 2007 | 05:07 PM
Adrenalin's Avatar
Project Fobra
That makes sense. Where would you place it, how high from the bottom of the front sump, or how low from the oil pans rim?
Click - FQuick
flickr
Old Jul 8, 2007 | 05:08 PM
i would put it above the oil level that way it will drain into the pan, otherwise you will have a column of oil sitting in the end of the hose.
Old Jul 8, 2007 | 05:21 PM
BigDawg's Avatar
has his prioritys ef'd up
Have you seen the DSS oil fitting?
Oil Fitting
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Jul 8, 2007 | 05:29 PM
Adrenalin's Avatar
Project Fobra
That's what I've been told, but here's the dumb question: How do I determine what the oil level is? Before I go and assume that I thread the dipstick tube into the pan and see where the level should be according to new dipstick, I just wanted to make sure first. I don't wanna go and make a dumb mistake.
Click - FQuick
flickr
Old Jul 8, 2007 | 05:30 PM
Adrenalin's Avatar
Project Fobra
Oil Fitting
Thanks BigDawg, I was typing up that reply before you posted lol!
-checking that site out now
Click - FQuick
flickr
Old Jul 8, 2007 | 05:51 PM
since the pan is out of the car, set it up where the top rail is level, then dump in 6qts of water, that will be the highest oil level.
Old Jul 8, 2007 | 05:58 PM
Adrenalin's Avatar
Project Fobra
Well hell, that sounds easy enough!
Click - FQuick
flickr
Old Jul 8, 2007 | 06:09 PM
Steve B's Avatar
brings his heater.
i'd put it in the back of the intake pouring into the valley, or t it into the valve covers.
