Need Help with Rear end.
Old Apr 27, 2007 | 03:38 AM
$hawn's Avatar
lives in a glass house
Originally Posted by riverviewnative
For all you dummies who don't know use a half inch box end wrench. Side it over the e brake cable and it will release. Good Grief. Have fun Chris thanks again for the tires.
how the hell do you get a closed circle box end wrench around a cable that is connected at both ends?
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Apr 27, 2007 | 09:20 AM
Mars_302's Avatar
Race Photographer
you can remove the one end from the parking brake itself, then you slide it down. Thats how I did mine
Old Apr 27, 2007 | 10:08 AM
$hawn's Avatar
omg mars, that snakes through the frame in at least two places before it even gets close to the parking brake! thats a whole lot of work to slide a wrench on to an e-brake cable...lol
or jusy grab a old 1/2 and cut a channel in the box end part with the cut off wheel and go to town
Old Apr 27, 2007 | 06:30 PM
riverviewnative's Avatar
Good Greif. The last time I pulled a rear end the e brake cables came off with it. Hence the ease with which they are removed. One 10mm bolt and Boom there is is. Slide that box in there and have some fun.
Old Apr 27, 2007 | 06:32 PM
Default Shawn
Please make sure that you have that happy gas vented out of the car.
Old Apr 27, 2007 | 08:43 PM
Mars_302's Avatar
Race Photographer
Two spots, thats it. Took me 5 minutes to pull mine thru.
fuckin lazy ass
Old Apr 29, 2007 | 08:08 PM
  #17 (permalink)
topher469's Avatar
BillionClub Member BISHES
didn't take out of car at all just out of drum!! NP less then 30 sec on each one.
Old Apr 30, 2007 | 02:58 PM
  #18 (permalink)
Megivern's Avatar
OK thanks guys for all the help. Now for some more questions.
Ok it looks like Im going to go with a 5 lug conversion on my car now as a last minute decision.
Right now Im running 4 lug cobra replicas with a rear size of a 17x10 with a 275 40 tire. If I go with Prostars, should I go with 15x10 or 15x8 and what would be the correct backspace? Also what size tire would be the best?
For converting the front, Ive heard that the lincoln mark 5's (or whatever they are) front rotors will work on the fox. Is this true? Im going to be running a 15x3 1/5 on the front.
My cobras will be up for sale with all tires plus 2 extra tires so if anyone is interested before I put them up let me know.
Thanks for the help.
The only thing tighter than my ride was your girlfriend.
Old Apr 30, 2007 | 03:10 PM
  #19 (permalink)
topher469's Avatar
yes lincoln rotors will fit. Bad is the hub will not fit any "stock mustang 5 lug wheels." you will be fine using welds. 10" look much nicer but I am not sure of backspacing.
Old May 1, 2007 | 07:34 AM
  #20 (permalink)
Megivern's Avatar
Anyone know the correct backspace and tire size on a 10 inch wide prostar on a fox body???
