Thread seal
DAMN!... I just tested it out and I just poured water into the radiator and bam it leaks AGAIN... from the bottom...
I am putting the spring first into the block... I don't get it.. I put the sealant on..
Now I fucked up the gasket taking it off and I don't think anybody is open today damn...
Ok I got it all together.. I used glue to hold the thermostat... and put the gasket on nicely. I put water in it with some flush to check it out and no leaks!!! I am going to drain and put the coolant in it..
Soo everything is going alright =)
THe only thing it is reading is a little higher than it used to.. It used to read a little below the A... Now it reads right between the M and A...
I wonder if this is because of the new coolant..
