Good launch shocks
Old Feb 10, 2006 | 12:13 AM
Little Nicky's Avatar
1140cc's of power
Default Good launch shocks
Ok im looking for some serious squatters for the rear and lifters for the front Keeping stock springs but i want shocks for the front and rear.BTW i have 4 cylinder springs in front.I'd like to go kinda cheap,nothing to expensive.Thanks for the help in advance.
Facebook
05 zx10r with a lot done still never will be stretched
Old Feb 10, 2006 | 01:22 PM
evocrazy1's Avatar
i run 90/10 lakewoods with 4 cyl springs up front, and 50/50 lakewoods in the rear, lakewoods are like 40 bucks each at autozone, just have too order them
ASKED TO BE BANNED
Old Feb 10, 2006 | 05:35 PM
allibabba's Avatar
I had a ex 4cyl that we converted and when we used the 4cyl springs all around it would launch just fine. I would try the above mentioned struts and shocks and take it to the track.
"Congressmen who willfuly take actions during wartime that damage morale and undermine the military are saboteurs and should be arrested, exiled or hanged".
President Abraham Lincoln
Old Feb 10, 2006 | 06:05 PM
bitemark46's Avatar
Got traction?
You don't want your rear suspension to "squat" at all. Squating reduces load on the tires and since there's no load you'll spin. Stock rear springs are fine. The rear shocks are about a 50/50 rates. Save your money and get some 90/10's on the front to match your 4cyl springs. If you can take as much weight off the front of the car as possible. -Mark
98' cobra
Old Feb 10, 2006 | 10:23 PM
evocrazy1's Avatar
iyou want the rear to squat if its a fox theres less weight in the back, Squating=weight transfer
ASKED TO BE BANNED
Old Feb 10, 2006 | 11:19 PM
Jap's Avatar
Jap
VTEC Out
Squatting = loosing momentum that could be used to propell the car foward ...
Hondata saves lives
Old Feb 11, 2006 | 09:00 AM
bitemark46's Avatar
Got traction?
Foxbody or not for weight transfer you want the nose to lift not nose to lift and rear to squat. Think about it, stand up with your knees locked, then very quickly squat down to your feet. There is less pressure on your feet when you are in the process of squating. Same thing in drag racing. -Mark
98' cobra
Old Feb 11, 2006 | 09:16 AM
topper's Avatar
hoes down pimps up
Old Feb 11, 2006 | 11:17 AM
bitemark46's Avatar
Got traction?
You know what you are all right. I have no idea how to get a good 60ft. Disregard my advice. Have fun cutting 1.7's. -Mark
98' cobra
Old Feb 11, 2006 | 11:41 AM
SteveIGuess's Avatar
SteveIGuess
im cutting 1.63's in my car on stock suspension, it dosnt squat at all, spins all the way down the track through 1st and the bottom of 2nd.... so if it were to hook it would raise up?
383 stroker, 500 of both worlds.....
