Good launch shocks
Old Feb 12, 2006 | 02:51 PM
  #21 (permalink)
Silver35thGT's Avatar
the only reason a cars rear should squat is if your tryin to take hit away from the rear ie bad track or tire limited.. The harder you can hit the tire the faster you will 60ft...Derel is 100% correct,,but its not ike I needed to say anything..
99gt automatic with some little mods 11.65@117.9.Before new motor and several more mods goin for the tens..
Old Feb 12, 2006 | 08:26 PM
  #22 (permalink)
Strokd85's Avatar
Daddy-O
Originally Posted by bitemark46
The voice or reason has spoken. Thank you Derek. I was hoping you'd chime in. 8.56@15X, you sure you know what you're doing? -Mark
I had help too..
Rob and Joe can tune a car from top to bottom. I learned a lot from them and others.
I am your penalty.....
Old Feb 13, 2006 | 09:27 AM
  #23 (permalink)
Steve B's Avatar
brings his heater.
i cut 1.39 60's and my rear doesnt squat, you want the tires to plant into the ground, which will raise the rear up, not squat.
look at my sig pic, the tire has more clearance to the top of the wheel well when launching.
Old Feb 15, 2006 | 07:05 PM
  #24 (permalink)
1fast351's Avatar
bite mark, i was told afco are the best for the rear as far as strut go true?
