Wheel help PLEASE!!!
Originally Posted by BlownBlue
Putting a 1/4" spacer in there am I going to have any problems with the wheel stud length being to short?
Just go buy some washers and find out, I doubt a 1/4" would make it a problem.
-Vince
-Vince
i wont be up there tonight, have to go help my father in law move some stuff..ill be there tomorow night
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
was it just 1 tire? On the Corral it was noted that some cars have slight variyation from the factory on the rear being center, mine was off 1/2" on 1 side. at first I thought maybe my car was hit at some point before I had it. My 275/60 DR's rubbed on my pass side, little clearanced and no problem.
Only 1/4 mile track I know is Gandy Bridge
i have never seen a mustang that had a rearend that sat perfectly straight in the car..lol
SLEEPER
SLEEPER
Guest
Posts: n/a
It doesn't have to be much. The rear end will move around some, but 1/2" gap should be fine. As the tire grows with speed, it will get narrower and taller, so if the side wall is rubbing, its probably not doing it at speed.
Go buy some play-doh, jack the car up, put a hunk on the tire where the gouge is and spin the tire. Check the play-doh to see if there's any marks on it.
