Wheel Bearing?????????
Old May 21, 2004 | 09:19 AM
Stephan's Avatar
Default Wheel Bearing?????????
ok when im coming to a rolling stop with my feet off of all the pedals i hear this clicking sound coming from my passenger side wheel. i thought it was a CV but i changed that and it still does it. could this be a wheel bearing? if it is a wheel bearing can i change it myself or do i have to get it pressed?
DSM Part Out
Old May 21, 2004 | 11:03 AM
Stephan's Avatar
DSM Part Out
Old May 21, 2004 | 11:19 AM
Stephan's Avatar
well it doesnt do it all the time. just every once in a while
DSM Part Out
Old May 21, 2004 | 11:44 AM
rangcrx's Avatar
engine building &best
yes the wheel bearing will click and now if it is going out with this hot ass weather its even worse the greas will just fall away if it is no longer sealed..as for doing it yourself you can do it your self with a LARGE hydro c-clamp or a yes it does have to be pressed in but to save money if i was you i would take apart yourself buy it then go to a 25$hour place and have them press it...but one way to see if it is going is jack the car up so the wheel is off the ground and see if there is alot of play in it it should only spin not wiggle......but the clicking may also be from what cronic said about your tranny diff.mioght be going
i love AUTOZONE
Old May 21, 2004 | 11:46 AM
Stephan's Avatar
ok now if my tranny diff is going can i just replace it or should i just get a new tranny? also i have a first gen b16a what diff could i use to replace mine if thats a better way to go?
DSM Part Out
Old May 21, 2004 | 01:06 PM
Stephan's Avatar
ok i went and checked the wheel bearing there is slight play in the wheel not much at all. when i turn the wheel while its in the air i hear a clicking coming from the tranny is that normal?
DSM Part Out
Old May 21, 2004 | 01:46 PM
Stephan's Avatar
i also drove it around my apartment complex and the sound is more like a clunk than a click
DSM Part Out
Old May 21, 2004 | 02:06 PM
rangcrx's Avatar
is your car lowered?sounds like it is,are you sure you have tranny fuild in there if it is low or you have none it will make that sound go check just undo the drain plug drain it out and change it with some 30Hd oil
i love AUTOZONE
Old May 21, 2004 | 02:08 PM
Stephan's Avatar
yeah i have fluid some drained out when i change the axle and also i just change the fluid about a month ago. but if it will help ill change it again
DSM Part Out
