3g Upgrade
Old May 9, 2005 | 05:39 AM
ODB's Avatar
ODB
S.Y.L.O.
Default 3g Upgrade
What a piece of cake....for you guys that have not done it...your silly....
Old May 9, 2005 | 06:11 AM
evocrazy1's Avatar
what do i need to do it, would it be better than my pa performance 120 amp alt
ASKED TO BE BANNED
Old May 9, 2005 | 06:20 AM
ODB's Avatar
ODB
S.Y.L.O.
94/95 mustang alternator.....gring your existing bracket...a little bit of soldering....and you done....129.99
Old May 9, 2005 | 02:41 PM
Leonard's Avatar
OUCH!!!
care to expand on that???
Old May 9, 2005 | 02:45 PM
ODB's Avatar
ODB
S.Y.L.O.
there a 2 connectors on the existing alt. one of them is a direct fit. The other has 2 large wires that are both black and ornge. Take those 2 wires and solder them together...then solder a smaller wire with a fitting on it. This will go to the post on the new alternator....then the little wire is easier....just put a terminal connector on it...and plug it in to the small pin on the new alt....that is it! 30 minute upgrade....other than grinding the bracket a bit.
New Pics Above!
Old May 9, 2005 | 08:15 PM
n8secstangg's Avatar
i told u it was easy!!!
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old May 9, 2005 | 08:30 PM
TheShow50h's Avatar
The little 5.0 that could
I'll bring my electric fan up to the shop tomorrow with that shiny new camshaft and you can put it on for me. We'll see if I need to upgrade then, I probably will regardless.
-Vince
Old May 9, 2005 | 10:21 PM
HELMUT RONER's Avatar
USAFR Veteran
I am cleaning up & clearancing a stock Foxbody alternator bracket and it will be for sale when done.
Helmut
Old May 10, 2005 | 01:06 AM
ODB's Avatar
ODB
S.Y.L.O.
It was simple......thanks for thr 411 Chad!
GiDDeNz
Nissan/Infiniti Tech
29
May 27, 2004 08:38 AM
cali
10
Aug 19, 2003 06:58 AM
Matt Vassallo
6
Mar 1, 2003 10:13 PM
