What is my best running temperature??
Old Apr 29, 2005 | 10:34 AM
ODB's Avatar
ODB
S.Y.L.O.
Default What is my best running temperature??
you all know I have a 351w/C4 in my coupe. I have a FMS aluminum rad....electric fan on a stat....I have a 180 thermostat...the car runs about 200-215...when I am in traffic...85 degrees out and nailing it....is this a good temp? I compared it to my GMC truck wich runs at 210 all the time....thoughts?? I think I am cooling efficiently...of course when the weather is cooler...the car runs about 190....thoughts?? thx
Old Apr 29, 2005 | 11:03 AM
351coupe's Avatar
refinish artist
With the c4 temps will be a little high in traffic,Chevys run hotter than Fords do,I would say your ok if it don't go over your 215 mark but don't let it get any higher.
Old Apr 29, 2005 | 11:12 AM
Flastangs's Avatar
Pat..your best running temp should be 98.6 degrees.
Old Apr 29, 2005 | 11:29 AM
ODB's Avatar
ODB
S.Y.L.O.
funny.............
Old Apr 29, 2005 | 11:54 AM
Flastangs's Avatar
Originally Posted by FOXBODYPAT
funny.............
you HAD to know that was gunna be said. Sorry to state the obvious.
Old Apr 29, 2005 | 12:12 PM
craig_302's Avatar
boostmonkey
Is the car carbed? If it isn't, then 190-200 is optimal...below 170 the ecu goes into closed loop and does not read off the mass air sensor from what I remember. If it is carbed, that should be fine, if a little high. I would throw some water wetter by Redline in there to get it down to the 200 max range. If you think it is running hot now, wait until the real summer heats pour on. The last thing you want is for it to overheat.
Old Apr 29, 2005 | 12:14 PM
TheShow50h's Avatar
The little 5.0 that could
+1, and +1 on the water wetter.
-Vince
Old Apr 29, 2005 | 12:27 PM
ODB's Avatar
ODB
S.Y.L.O.
shit...it is summer bro.....it's running at 200 when I'm beating on it....it maybe bumps to 210...just ran it home today...it is carbed.....I think I am fine....thanks for the input!
Old Apr 29, 2005 | 12:53 PM
Steve B's Avatar
brings his heater.
i have a stock radiator and a stock waterpump. 186 degrees all day.
straight water + water wetter
Old Apr 29, 2005 | 01:14 PM
ODB's Avatar
ODB
S.Y.L.O.
when you beating it also??? you got 180 stat??
