What is my best running temperature??
Old Apr 29, 2005 | 01:17 PM
TheShow50h's Avatar
The little 5.0 that could
Originally Posted by rubberneck
i have a stock radiator and a stock waterpump. 186 degrees all day.
straight water + water wetter
+1, when mine was running right the car wouldn't get above 185 driving normal or over 190 after making a pull with a new stock replacement pump and radiator. 70/30 water/coolant + water wetter.
How old is your waterpump, and what kind of electric fan Pat?
-Vince
Old Apr 29, 2005 | 01:38 PM
ODB's Avatar
ODB
S.Y.L.O.
waterpump is about 1 yr old....fan is off 90 sumthin V8 explorer.....running 70/30 anti freeze...no water....
maybe need more fan?? I don't know cfm of fan....I'm gonna check to see if it has a Ford part number on it....brb
Old Apr 29, 2005 | 01:41 PM
TheShow50h's Avatar
Hmm, if you want to give my black magic dual fans lmk, I think they pull around 2600cfm.
A stock 5.0 explorer fan is probably the same as an sn95 fan so it should be sufficient enough to keep the car closer to 180 than it is though imo.
-Vince
Old Apr 29, 2005 | 01:51 PM
ODB's Avatar
ODB
S.Y.L.O.
I can't read the specs on it...I'm going to unbolt the fan tomorrow and take a look.....PM me your cell again...thx
Old Apr 29, 2005 | 02:14 PM
Steve B's Avatar
brings his heater.
do you have a standard rotation fan on a reverse rotation water pump or vice versa? which way does the air blow?
Old Apr 29, 2005 | 03:28 PM
ODB's Avatar
ODB
S.Y.L.O.
puller.....reverse water pump rotation
Old Apr 29, 2005 | 03:54 PM
  #17 (permalink)
Steve B's Avatar
brings his heater.
hmmmmm
Old Apr 29, 2005 | 03:58 PM
  #18 (permalink)
ODB's Avatar
ODB
S.Y.L.O.
hmmmmm
yeah..hmm.don't get me wrong....the car is not running hot...I'm thinking I should run a little cooler...I'm gonna check the specs on my electric fan...the fan is about 19"...it isn't small.....and I'm gonna check the wetter water shizzle too...the rad is clean and flowing...maybe I should do a water pump upgrade...something better than stock....
Old Apr 29, 2005 | 03:59 PM
  #19 (permalink)
Steve B's Avatar
brings his heater.
does your transmission cool through your radiator, do you have an external cooler as well?
Old Apr 29, 2005 | 04:08 PM
  #20 (permalink)
ODB's Avatar
ODB
S.Y.L.O.
yes.....and ....yes....tranny is running through the rad...then through another cooler mounted between the rad and A/C condensor
