Holley Carb help
Old Apr 23, 2005 | 08:01 AM
ODB's Avatar
ODB
S.Y.L.O.
Default Holley Carb help One last ???
I have been asking here and there on how to tweak this carb for max perf. I still need to bounce some things off you guys...
It is a brand new 600 DP. I bought the Holley Jet kit. The carb comes stock with #66 mjets. I spoke to the guys at A&E and he asked what the symptoms are....here's what they are;
from a start if I hit it hard it bogs and then takes off after I feather the pedal...the guys at A&E say I should go down a squirter size.
Laurie Holly says I should bump up a jet size from stock....
Rubberneck agrees....
Last is...my accel arm get's kinda stuck when I mash the pedal....sticks at 3K...I get out and bump it and it goes back to normal idle speed....how do I adjust the accel pump to keep this from doing the same shizzle...
PS
motor is 351W with very mild cam and internals....C4 behind it.....Weiand Stealth intake..stock but totally rebuilt heads....
any volunteers to help?? I'm buying lunch...beer/beverages and party favors...
Thank in advance...
Old Apr 23, 2005 | 08:54 AM
Steve B's Avatar
brings his heater.
smaller squirter in the front. dont change the jets yet.
get a stiff return spring too.
Old Apr 23, 2005 | 08:56 AM
ODB's Avatar
ODB
S.Y.L.O.
Laurie Holley say bump one up on jets.....do squirt firt?Spring is tight as fuck.. thx ya bastich haha..
Old Apr 23, 2005 | 09:01 AM
Steve B's Avatar
brings his heater.
the squirter is on top of the carb, you can change it without disassembling the front too.
http://www.bob2000.com/carb.htm
Old Apr 23, 2005 | 09:12 AM
DrDirt's Avatar
Team Geritol Racing
How 'bout the power valve ?Did ya have a backfire anywhere along the line. Sometimes it only takes 1 pop to blow out the power valve. Makes for a lousy tip in.
YO! Barry! You LOST!
Old Apr 23, 2005 | 09:16 AM
Steve B's Avatar
brings his heater.
check for vaccum leaks, make sure your intake bolts are all tight and all your extra vacuum ports are plugged.
Old Apr 23, 2005 | 09:39 AM
ODB's Avatar
ODB
S.Y.L.O.
no pops....the car has an anti popping power valve....and all vaccuum is good...no leaky...I'm goin' to do it shortly.....thanks guys...I'll keep ya posted....I also picked up 2 smaller and 2 larger squirters from A&E
Old Apr 23, 2005 | 09:41 AM
ODB's Avatar
ODB
S.Y.L.O.
I already have visited this page!! thanks .....I'm still asking ?? too...thx
Old Apr 24, 2005 | 05:04 AM
chevy eater's Avatar
squirter is the way to go,have you looked at the plugs?
this will give you an idea if the jetting is off
Squirters will cause this bog you have as well if the accelerater pump is not adjusted right
Old Apr 24, 2005 | 05:35 AM
ODB's Avatar
ODB
S.Y.L.O.
and tell me how to adjust the accel pump.......
I just changed the squirter from the original #28 to a #25...then I pulled off the front(didn't touch the back yet) and re jetted from original #66 to a #68 and the car moves right right out of the box....should I play some more?? or should I play and check plugs...then go up in size until I see to rich...then back down??
