pro5.0 shifter problems
Old Jan 20, 2005 | 03:43 PM
BDIX's Avatar
Dick is Huge!
Default pro5.0 shifter problems
I got a question...
does a shifter popping out of a gear mean the stops arent adjusted far enough back?
Totalled his shit!@
Old Jan 20, 2005 | 03:53 PM
TheShow50h's Avatar
The little 5.0 that could
The shifter could be loose, the stops could be adjusted too short, or your shiftforks are bent.
-Vince
Old Jan 20, 2005 | 04:30 PM
Steve B's Avatar
brings his heater.
Old Jan 20, 2005 | 06:39 PM
SoL_93GT's Avatar
Wrong, the synchros are bad, this is very common in Mustangs, you need a basic rebuild. Do it soon, the more you drive it like that the more damge you will do to the transmission and it will be more expensive to fix if they have to replace any gears.
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Jan 21, 2005 | 06:16 AM
BDIX's Avatar
Dick is Huge!
transmission is freshly rebuilt.
I think the stops are set to short, though I'm kinda dissapointed in the shifter... I drove my buddys pro5.0 and it felt alot smoother and more precise?
Idk if these things break in or not but maybe that could be it?
Totalled his shit!@
Old Jan 21, 2005 | 09:36 AM
Stangonline's Avatar
Just back the stops all the way off and see if it still does it. Dont rule out the possibility that the rebuilt tranny still needs some love. Where did you get it from? Theres no way to "test" a tranny when its rebuilt until you put it in your car.
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
