Carbureted intake manifold for DOHC modular engines !
Old Jan 13, 2005 | 04:27 PM
  #41 (permalink)
Stangonline's Avatar
Retail its $899 - It might have been cheaper before, but they just redesigned it too. I know a guy who is a AFM dealer, so hopefully I can get a buddy discount there
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old Jan 13, 2005 | 04:31 PM
  #42 (permalink)
SoL_93GT's Avatar
Whats different about it now?
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Jan 13, 2005 | 04:38 PM
  #43 (permalink)
now it looks like a gameboy
Heres a clip from their site. Seems like the biggest change in the stand-alone mode.
We now have the upgrade kits for the 98-03 PMSs to give
them the new 04 PMS features which are:
* Single Data Display Screens lets you monitor spark timing, injector %, oxygen sensor voltage, mass air flow voltage, water temp, air charge temp and intake manifold pressure/vacuum.
* Easier to use controller with all load tables on one screen with adjustments down to 500 rpm increments starting at 2000 rpm and up.
* Stand alone turn on control adjustable by RPM and throttle, fuel and timing each separate adjustments.
* Fuel and timing adjustment by air charge temp and water temp.
* Can use nitrous control and two step rev limiter at the same time.
* Global fuel control.
Jeff
Old Jun 28, 2017 | 09:39 AM
  #44 (permalink)
Fuel Injection vs Carbs?
Turbo?
