fuel pump info
Old Jul 31, 2004 | 08:24 PM
96fcobra's Avatar
Question fuel pump info
i am replacing my stock fuel pump from my 96 ford cobra. i wanted to know if this will severly effect my gas mileage even with normal driving and if a 255lph is to big?if so what should i throw on it?
Old Jul 31, 2004 | 09:28 PM
TIM TIM TIM's Avatar
could be worse
thats clean for a 96..
aim:because tim said
Old Jul 31, 2004 | 10:59 PM
BLUE2KSS's Avatar
Mechanical Engineer
Default Re: fuel pump info
well, what engine modifications does the car have?
Old Jul 31, 2004 | 11:12 PM
BlackSunshine's Avatar
I am assuming that the engine is pretty much stock and if it's not that it has just minor stuff. Get a Walbro 190 lph fuel pump. No it will not severely effect your gas mileage. Don't be talked into some expensive brand because most likely it is a Walbro with a "" sticker put on it.
"Gripping the wheel his knuckles went white with desire, the wheels of his mustang exploding on the highway like a slug from a .45. True death. 400 horsepower of maximum performance piercing the night, this is Black Sunshine"
Old Jul 31, 2004 | 11:14 PM
Bald Guy's Avatar
I like beer.
You don't need a fuel pump unless you plan on adding a blower or spray.
-Jomar-
Old Aug 1, 2004 | 04:57 AM
Leonard's Avatar
OUCH!!!
Use some common sense here....
Unless you increase your injector pulse width, injector size or fuel pressure (via a fuel pressure regulator) or change your fuel maps in your ECU, you're not going to put any more fuel into the cylinders. Thus your mileage won't really change.
Old Aug 1, 2004 | 09:42 AM
Strokd85's Avatar
Daddy-O
what is the reason why you are replacing the pump and what are your future plans? answer those questions and go from there.. 190 or 255 will be fine depending on what your plans are.
I am your penalty.....
